Paint match for Countach Options
pzspeed
#1 Posted : 28 December 2019 20:28:49
Hello all,
Does anyone happen to know the paint match for the red on the Countach? I have several blemishes I need to fix. Not very happy with the finish on a $1,400.00 kit.
Thanks,Pat
#2 Posted : 28 December 2019 21:02:53
I very much doubt you will get a paint match for the red as its probably an in house color used by the Chinese manufacturer where the parts came from.
You could contact C/S for replacements of the faulty parts or you could do a strip and repaint of all the body parts like I did with my GT 2000.
Zero paints do Lambo colors link below-
https://www.hiroboy.com/...60ml--product--987.html
Or you could try Gravity or Splash paints in the USA.
steele
#3 Posted : 17 February 2020 23:47:46
Rank: Amateur Level 1
I own many bright reds, and bought several more for this project, including all the colors mentioned in the instruction book as being a match and to use for touchup----the closest match of all IMHO, was Testors Guards Red, the enamel version. For "single coat touch-up" it is the closest of all, though even then, not absolutely utterly 100% perfect.
pzspeed
#4 Posted : 20 February 2020 03:46:56
Mr Color#68
This page was generated in 0.254 seconds.
