Would a 9V battery replace the external power supply? Options
x_dfo
#1 Posted : 29 December 2019 19:36:05
Rank: Advanced Member
I read the spec of the external power supply was DC9V - I'm assuming I could just wire in a 9V battery to replace it no?
Cheers and Happy Holidays!
#2 Posted : 29 December 2019 20:02:32
You get two choices, 9v through mains adapter and then battery option which is 6v, 4x AA batteries. Just use the supplied battery box option.
tschwand
#3 Posted : 29 December 2019 20:23:38
You could try ordering the external mains from DeAgostini but the one I received did not work due to reversed polarity. Bought this one from Amazon and works great. https://www.amazon.com/g...4_s00?ie=UTF8&psc=1
x_dfo
#4 Posted : 29 December 2019 20:56:24
I'm actually trying to avoid using the internal battery pack and also the need to trail a power cable down from the mount on the wall. I figured I could hide a 9v battery pack on the underside.
#5 Posted : 30 December 2019 01:09:28
IF you want to use batteries I would not use a 9V battery. Using 6 AA in a battery pack would be OK, but the LED strips in the falcon will drain a 9V battery pretty quickly.
x_dfo
#6 Posted : 30 December 2019 01:37:23
Ah yes, due to the low mah - thanks for the tip!
This page was generated in 0.211 seconds.
