Parts help Options
Heinzy
#1 Posted : 23 August 2011 11:07:55
Hi all,
long time reader, 1st time posting BigGrin
I've been building my Mclaren quite event free up until issue 18, yes even the rear wing went together fairly ok with no dramas!
But whilst screwing the lower brace and push rod together my screw head sheared off and broke, leaving me with a useless push rod with a screw stuck in it that I cant get out Crying
My question is.....
Can i buy the parts only for this, or have i got to spend £7.99 on the whole issue again?
Any help would be much appreciated
Dean
The Brawn Build
Wentworth Court Dolls House
The MP4/4 Build
Austin
#2 Posted : 23 August 2011 11:34:26
Pretty sure you will struggle getting spare parts, I'd just go and get the issue again. It's a bummer but it will be the quickest route me thinks.
#3 Posted : 23 August 2011 12:34:34
Replacement parts are supplied with the magazine at the cover price, though you may be able to find what you need on such as eBay at a lesser price.
Austin
#4 Posted : 23 August 2011 14:36:33
So what your saying mr t is that the replacement parts are the same price as getting the issue again?
kryten2b
#5 Posted : 23 August 2011 15:01:03
Lubrication, Lubrication, Lubrication BigGrin
It is a good idea to keep a pot of vaseline (or other suitable substance) by your workbench & just dip the tip of the screw in the jar before use - the screw will go in with much less effort & will be much less likely to strip the head or thread ThumpUp
Well spin my nipple-nuts & send me to Alaska
Current Builds:
McLaren MP4-23Finished
007's Aston Martin DB5Finished
Millennium Falcon
R2-D2
BTTF Delorean (Maybe)
Heinzy
#6 Posted : 23 August 2011 15:23:05
I'll keep an eye on ebay then, see what pops up
Thanks for the advice on the lube, i'm sure i've got some in the garage!BigGrin
I thought i'd ask too as I did notice on the Japan site the seperate page for parts
http://deagostini.jp/select/ser...ion=1&title_code=mcl
And i've read all the backwards and forwards about it being a different franchise with a different amount of issues, I just thought it was a good idea and if anybody knew if DeAG uk was going to follow suite
cheers
The Brawn Build
The MP4/4 Build
rcollison
#7 Posted : 03 September 2011 12:32:05
Rank: Beginner Level 1
There are plenty of issues on E-bay at the moment.
scottww86
#8 Posted : 03 September 2011 13:43:32
on a slight tangent, i dont understand why somebody would buy issues and put them straight on ebay?? wheres the sense in that? Confused
f1marshal
#9 Posted : 04 September 2011 11:21:47
Well after looking at the japan site selling the parts i cant see why the uk site cant do the same as it is the same company or are we that far behind with the times and still trying to play catch up
Well admin will anything be done or not?
Confused Confused Confused Confused
Paul
Current builds:
1/24 Spitfire
1/48 Apache Longbow
Titanic Lifeboat
Heinzy
#10 Posted : 05 September 2011 10:13:34
I got the issue on ebay, and made a savingBigGrin
All put together now and looking sweet!
So i have a spare rear right suspension arm and push rod now if anyone wants it
and a spare issue 18 mag!
The Brawn Build
The MP4/4 Build
This page was generated in 0.141 seconds.
