SkyFire's Bluenose Options
skyfire
#1 Posted : 30 December 2019 14:24:10
The 1st photos of the build. Enjoy :)
Bluenose and the Bismarck
Box Cover
Inside The box 01
Inside the box 02
Hull Planking - Lime on the left, Walnut on the right
Deck Planking - lime
Spars
Wood Sheet 01
Wood Sheet 02
Wood Sheet 03
skyfire
#2 Posted : 30 December 2019 14:25:30
If you build the Amati Bluenose beware there is an error in the plans, (or in the instruction book). Luckily found it before I had gone to far. At least when I was building her anyway, it may have been fixed by now!
Parts 15 & 16 should be 17 & 18.
Parts 17 & 18 should be 15 & 16.
skyfire
#3 Posted : 31 December 2019 12:45:58
Latest photo of the build.
Latest photos of the build. Masts are not glued in yet.
Latest update on the bluenose build. I have been adding some reinforcing parts behind each of the ribs to gives the planks something more to stick onto.
skyfire
#4 Posted : 01 January 2020 08:59:28
The deck planking is now complete, just need a small amount of filler along the edges.
skyfire
#5 Posted : 01 January 2020 12:02:08
I have started the hull planking of the Bluenose.
Bow
Stern
Port
Starboard
daffy09
#6 Posted : 01 January 2020 14:00:54
Happy New year Skyfire.
I like the way your Bluenose is taking shape now. This is a model that I've often thought about building myself and your diary has given me fresh inspiration.
P.S: love your little footnotes, I hadn't seen that one about fear before - thank you.
Happy building
David
skyfire
#7 Posted : 02 January 2020 12:11:39
Been doing some more hull planking since the last lot of photos.
skyfire
#8 Posted : 05 January 2020 08:11:35
Major update on the Bluenose, 1st layer hull planking is now complete.
Starboard
Port
From the bow
From the stern, still need to fit a piece here.
#9 Posted : 05 January 2020 11:55:54
Coming along very nicely, very well done....Cool Cool
skyfire
#10 Posted : 11 January 2020 07:22:54
More photos.
#11 Posted : 11 January 2020 12:36:50
Very tidy work, looking excellent.Love Drool
skyfire
#12 Posted : 12 January 2020 08:55:57
I have finally completed the 2nd layer planking on the Bluenose. I just need to do a bit of trimming round the bow and plank the stern piece, (optional in the build).
skyfire
#13 Posted : 12 January 2020 09:20:50
Latest photo of the build, this time of parts that make even Bissys 2nd layer planking seem ultra easy. They are very short pieces of 1 by 2 mm limewood that go from the deck to the top of the bulwark, (marked by the white lines). There is 44 of them to be glued on, so far I have a total of 4.
Btw ignore the pencil markings, they're in the wrong place. Pencil lines won't be visible after it's painted and the top pieces go on.
z8000783
#14 Posted : 12 January 2020 13:46:03
Groups: Unapproved
Great work Anthony. This is really motivating me to get going on mine again.
#15 Posted : 12 January 2020 17:40:51
Looks very nice.
I really like the look of these models (something without guns :-) )
Looking forward to your next update.
Tony
skyfire
#16 Posted : 15 January 2020 08:53:22
Thanks
Well some more work on the Bluenose. These small pieces of wood that represent the frames are worse than the planking on Bismarck.
The small pieces I have done are spaced 12mm apart. I used a scrap piece of deck planking cut to 12mm as the spacer between each part and ended up with 13 each side, (plans showed 12 each side). Someone else on the course worked out the 12mm spacing and, (I think) had the right number.
skyfire
#17 Posted : 15 January 2020 09:01:28
I have at long last finished the small pieces of wood that represent the frames. All 46 of them, 23 each side.
skyfire
#18 Posted : 15 January 2020 09:02:35
Another update. 1st part of superstructure added.
#19 Posted : 15 January 2020 19:17:13
Thats coming along at a fair old pace and its looking very nice indeed.
Tony
#20 Posted : 15 January 2020 20:18:17
Wow, you are certainly cracking on with this. Looking good.Love Drool
This page was generated in 0.240 seconds.
