status lights Options
stin55
#1 Posted : 31 December 2019 20:09:03
Rank: Beginner Level 1
Hi Guys
finally, put my R2 together. After some initial issues with the head movement I now have everything working with the exception of the main status light, it only every shows red or its off, never blue or purple. i have tested the light with the test board in issue 1 and it will display the blue light when attached to the test device. I have checked the cables and reseated them any advice? which part might need replacing?
Justin
#2 Posted : 01 January 2020 10:58:18
Here is a troubleshooting guide which may help you.
https://forum.model-space.co.uk/...aspx?g=posts&t=32756
It usually means the batteries are not fully charged, check the spec of your batteries as well as checking the status of them within the app.
Hope that helps.
stin55
#3 Posted : 05 January 2020 23:16:57
hi
thanks for your reply I have followed the troubleshooting guide and prepared the batteries again just in case but still have the same issue, whenever the light should be purple it's red when its meant to be just blue its blank. for example during charging in flashes red.
Justin
#4 Posted : 06 January 2020 10:30:33
A red light usually means a battery issue. What batteries do you have?
No protection, 2600mAh etc
stin55
#5 Posted : 21 January 2020 15:04:34
Hi Mark
i have the below, i don't believe its battery issue
Samsung 30Q 18650 3000mAh Battery Button INR18650-30QBT 6
Justin
#6 Posted : 21 January 2020 18:27:37
Hi Justin
It might be worth checking the battery box output with a multimeter if you can get hold of one. The instructions are in the guide.
stin55
#7 Posted : 22 January 2020 11:08:35
Hi Mark
i'll give that ago, if it turns out not to be the battery's how do i go about getting replacement parts?
Justin
#8 Posted : 22 January 2020 16:55:12
Give that a go, and see what voltage you are getting. If you need a replacement part, contact C/S who will help you.
stin55
#9 Posted : 27 January 2020 23:14:01
Hi Mark
Getting 12.4 on the battery box, checked all cabling again. what part controls if the light goes red,blue,purple?
Justin
R2D2Nut
#10 Posted : 28 January 2020 18:53:12
Probably the small two wire connector
stin55 wrote:
Hi Mark
Justin
#11 Posted : 28 January 2020 20:08:24
stin55 wrote:
Hi Mark
Justin
This is new one on me. Have a look at the distribution board in the dome for any slightly bent pins. If all looks okay contact C/S for a replacement distribution board in the dome from issue 66.
stin55
#12 Posted : 24 April 2020 16:04:17
Hi Guys
after 3 months finally got a reply from customer services but all they said was they have no stock of issue 66 so looks like i'll need to hunt on Ebay. I would have thought they would keep some spares should things go wrong, oh well.
Justin
stin55
#13 Posted : 14 January 2021 20:29:22
Hi Guys
finally got around to fitting new distribution Board, this made no difference the light still won't do purple or blue. I think I'll go for a new light even though it works on the test board. any other ideas welcomed?
]ustin
#14 Posted : 14 January 2021 23:34:42
It still sounds like a wiring issue. Check you’ve got the lighting connected to the right connectors. It maybe you have the rear and front lighting connected the wrong way round. Bent pin in the socket, etc.
S4Simon
#15 Posted : 15 January 2021 02:48:37
Publisher Medal: Featured Build of the MonthBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
I’d also be leaning towards wiring and connection points. Connect the light back up to test board and move the light and wiring around (wriggle test) to see if there is any intermittent issues. Then i’d just check the solder points on the lled circuit board.
BUILDING: Taking a break / Waiting for the next epic build to be released
COMPLETED: Hachette Spitfire, Hachette Bismarck, Deagostini Millennium Falcon, Deagostini R2-D2
This page was generated in 3.445 seconds.
