Yamato build Options
builderphil
#1 Posted : 23 August 2011 20:28:18
Hi all,well i've finally started to build the Yamato,to overcome the missing/wrong frame 7 i've cut the 2 studs off a frame 8 and left in the correct position for the time being.Will post pics at a later date,when i've built 3/4 sections of the base/keel.Bye all,happy modelling.Just got to wait for issue 2 >Phil
builderphil
#2 Posted : 27 August 2011 16:37:52
Ever heard of the invisible man?because that's how i feel at the moment,posted various messages on the forum,only had 1 reply,must have done something awful in a previous life.Confused
#3 Posted : 27 August 2011 16:40:45
BigGrin your not forgoten m8 and gl with the build, by the way im just ahead of you really, just recieved pack 3 waiting now for pack 4 and iv subcribed to the akagi aswell
budgie
#4 Posted : 27 August 2011 18:53:43
BigGrin Hi builderphil you probably get the correct frame in your second delivery as i did
Confused got confused myself with same prob as yourself
Cool get some pics up of your build
builderphil
#5 Posted : 28 August 2011 18:01:29
Hi Arpurchase,thanks for reply,how's ur build coming along?i've nearly completed the 1st issue,just the bow section to do.I'm going to building 3 ships they are Yamato,Cutty Sark from Deag & the Hood from Hachette,should keep busy for a while.Cheers m8,be in touch later.Phil
builderphil
#6 Posted : 28 August 2011 18:06:16
Hi Budgie.thanks for reply,from what i've been reading on the forum,ithink that the correct frame will b in the next delivery,hope so,will be posting some pics in the very near future.How's your build coming along?,cheers m8,catch u later.Phil
#7 Posted : 28 August 2011 18:37:40
BigGrin Hi Phil check out my build diary to see my progress, had a few issues with warped former[14] but sorted those with the soak and clamp method. so far the quality of the parts is good looking forward to seing your build diary
builderphil
#8 Posted : 28 August 2011 22:11:17
Hi ArPurchase,just checked out your build diary,it's looking gud,just hope mine comes looking nearly as gud as yours,cheers m8 speak laterDrool
#9 Posted : 28 August 2011 22:14:06
thanx 4 the comments m8 soon il be reciprocating i hope
builderphil
#10 Posted : 16 September 2011 10:46:22
Hi all have finished putting the frames in onto the hull,must say it's looking gud,still trying to put pictures on to the forum.Have a question or 2 for Mr T,what colour grey are u using for the hull and superstructer,is it Kure as i have seen on white ensign's site,what size eylets are u using,and what size are the ladders & stanchions should i get?any help most greatfully recieved,thanks.Phil
#11 Posted : 16 September 2011 11:02:25
Hi Phil, paint info is noted in my build, for this build I chose Tamiya aerosols TS-66 Kure Grey and TS-33 dul red for below the waterline, both have a nice satin/matt finish rather than being totally flat.
Deck edge stabchions are provided in the kit, though are brass pins and threaded between; unsure what you mean about ladders, as PE ladders are provided in the kit
This page was generated in 0.550 seconds.
