First a little about myself, iv been modeling since i was a kid plastic keil craft gliders, then i got into radio control aircraft but started making more scale types i finaly decided i liked building more than flying. then a gave things a rest for about 8 years. then the itch starts in the back of your head to build something so here i am File Attachment(s): 049.JPG (299kb) downloaded 178 time(s).arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
S orry about the pic quality il try to do better next time as i add Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Welcome to the forum, look forward to seeing your hard work Looks like your getting flash bounce and the focus is way out, I'm sure you'll quickly get the better of it.
Thanks for the welcomw mister T hopefully il get thigs sorted as i take more Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Welcome to the forum, we all have to learn, your photos will get better!!!! MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 W0000000000000000T found my davids razor plane[best modeling plane on the markest in my opinion] also came across 10 piece riffler file set at maplins £2:99 should be handy for the metal parts Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi a few more pics sorry about quality but im using an old digi camera thats got a mind of its own when focusing  B ut i hope it gives a general idea of my progress so far Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Coming along nicely MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Thanks MWG Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
More bits arived today  not a mega package this time but some intresting things to do[ 1st time iv used photo etched components].some of the boat deck parts had warps but used those to my advantage as i didnt need to bend parts no 4  . i also used the offcuts on parts3 as fillets between bulkheads 17/16 to add strength and cure the twist i had there Andy ps still have the carving of the bow to keep me occupied arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
some more pictures arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Bow rough sanded and atached now just to wait for the 4th part about 3 weeks away  .But at least il get the tool kit with this issue arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
up to pack 4 now arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Photos are much better You might want to smooth and fill the joints between all the base sections, otherwise some of the superstructure parts may not sit flat or even rock, and any stepped joint lines will stand out a mile; the entire surface of the base shoild be flat and without visible joins, a lot of work I know but its worth the effort.
Nice work MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
 Thanx mgm for the kind comments, the base actualy looks worse than it is becuase of the shadows from the flash its exactly 0.005 diffrence in height, but if mr t would advise if this will make/cause a problem then il get the file out Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
If you have height difference shadowing then I would suggest they are sorted.
Ok mr t will sort it Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
