Joined: 20/01/2011 Posts: 608 Points: 1,753 Location: Canberra, Australia
The 1st photos of the build. Enjoy :) Bluenose and the Bismarck  Box Cover  Inside The box 01  Inside the box 02  Hull Planking - Lime on the left, Walnut on the right  Deck Planking - lime  Spars  Wood Sheet 01  Wood Sheet 02  Wood Sheet 03
If you build the Amati Bluenose beware there is an error in the plans, (or in the instruction book). Luckily found it before I had gone to far. At least when I was building her anyway, it may have been fixed by now!
Parts 15 & 16 should be 17 & 18. Parts 17 & 18 should be 15 & 16.
Latest photo of the build.  Latest photos of the build. Masts are not glued in yet.    Latest update on the bluenose build. I have been adding some reinforcing parts behind each of the ribs to gives the planks something more to stick onto.
I have started the hull planking of the Bluenose. Bow  Stern  Port  Starboard
Happy New year Skyfire. I like the way your Bluenose is taking shape now. This is a model that I've often thought about building myself and your diary has given me fresh inspiration. P.S: love your little footnotes, I hadn't seen that one about fear before - thank you. Happy building David
Major update on the Bluenose, 1st layer hull planking is now complete. Starboard  Port  From the bow  From the stern, still need to fit a piece here.
Coming along very nicely, very well done.... Regards Alan
Thanks :) More photos.
Very tidy work, looking excellent. Mark Regards Markwarren (Mark) Admin
Latest photo of the build, this time of parts that make even Bissys 2nd layer planking seem ultra easy. They are very short pieces of 1 by 2 mm limewood that go from the deck to the top of the bulwark, (marked by the white lines). There is 44 of them to be glued on, so far I have a total of 4. Btw ignore the pencil markings, they're in the wrong place. Pencil lines won't be visible after it's painted and the top pieces go on.
Great work Anthony. This is really motivating me to get going on mine again.
Looks very nice. I really like the look of these models (something without guns :-) ) Looking forward to your next update. Tony Happy Modelling
Thanks Well some more work on the Bluenose. These small pieces of wood that represent the frames are worse than the planking on Bismarck.  The small pieces I have done are spaced 12mm apart. I used a scrap piece of deck planking cut to 12mm as the spacer between each part and ended up with 13 each side, (plans showed 12 each side). Someone else on the course worked out the 12mm spacing and, (I think) had the right number.
I have at long last finished the small pieces of wood that represent the frames. All 46 of them, 23 each side.
Another update. 1st part of superstructure added.
Thats coming along at a fair old pace and its looking very nice indeed. Tony Happy Modelling
Wow, you are certainly cracking on with this. Looking good. Mark Regards Markwarren (Mark) Admin
