Yard Arm Footrope supports Options
daffy09
#1 Posted : 24 August 2011 15:04:03
Hi shipmates
Here's an alternative idea for the footrope supports. Having tried the magazine method of twisting the supplied brass wire, I was not very happy with the finished result. I have achieved a finish that is much more pleasing to me by the use of brass eyepins such as the type we used for the handrails of the grating companionways on the upper gun deck.
After purchasing a few packs of the eyepins from Cornwall Model Boats, I carefully drilled holes in underside of the yardarm with a 0.7mm drill at the required points on the plans and super glued them into place. This method provided me with much more control over the length - being able to achieve a more uniform drop on each footrope support.
Happy building
Daffy09
#2 Posted : 24 August 2011 17:30:12
Just wait until you come to wire-loop the deadeyes for the chainwales @75 Cursing
StefanDV
#3 Posted : 24 August 2011 22:06:13
alantait
#4 Posted : 24 August 2011 22:39:57
Mr T. your beginning to worry me with the above post, my fingers wont do what they are told anyway but issue 75 might need to ask my 2 year old grandson, at least he has the eyesight and nimbleness with his handsConfused
current builds
#5 Posted : 24 August 2011 22:52:00
See how you get on with the yard footrope supports, the wire looping of the deadeyes is a similar process but lots of them, once you've done a few you'll soon get the hang.
alantait
#6 Posted : 24 August 2011 23:12:11
only on issue 65 at the moment so plenty time to buy calms for the nerves and let them get to workLOL LOL LOL
current builds
#7 Posted : 25 August 2011 12:27:40
Mr T you have a way with wordsCool
This page was generated in 0.043 seconds.
