2 Pages 12>
Pocher kits Options
Mustang
#1 Posted : 23 January 2020 10:47:57
Hi all,
I’ve managed to get hold of 3 Pocher kits Rolls Royce, Mercedes and an Alfa.
The Rolls and Merc are already built and will need a strip down and rebuild and some new parts, the Alfa is in bits and I’m sure it’s missing bits.
The question I have is two fold, 1st does anyone have the manuals for these I now I can download these but looking at the download version they don’t look complete. 2nd the Paul koo dvd is it worth the £40 that they seam to go for or does anyone have a copy they don’t want anymore.
To build:-
#2 Posted : 23 January 2020 11:37:54
Ian
Not sure if this helps but this site has manuals for free download.
Apologies if its one you have already tried.
Tony
http://www.pocher.net/english/modelmanual.html
https://www.modelmotorca...ful-info/pocher-manuals/
CaptnBirdseye
#3 Posted : 23 January 2020 13:40:21
Rank: Superelite
Now if you'd have gotten the Ducati Panigale, i could have helped you there RollEyes
#4 Posted : 23 January 2020 16:23:16
I second Marvins website modelmotorcars.They also have build guides on CDs that are cheaper than the Koos ones.The Koos ones are very good and definitely worth the money-Just to help you avoid the MANY frustrations that are inherent in building Pocher cars.
Mustang
#5 Posted : 23 January 2020 17:02:01
Cheers Tony, I did look there but it must just be the way the manuals are done they just seam to jump about and the last page showed the model still in bits Blushing
I'm just to use to plastic kits Laugh
I've just finished the pocher Ferrari Testorossa, but waiting for better weather so I can get some photos outside.
To build:-
Mustang
#6 Posted : 23 January 2020 17:05:59
Captain thanks for the offer, yes I do have the Ducati still in its box with a copy of the Paul on usb plus some extras and new rear wheel nuts that I 3D printed.
One day I might get around to building it and the Busa.
To build:-
Mustang
#7 Posted : 23 January 2020 17:08:01
Thanks for the info Carl, it's nice when someone has had one of the items and can give a little insight into it. Smile
To build:-
#8 Posted : 23 January 2020 17:16:06
Agree on the weather - its just so dark. We used to get some cold winters but bright days, this year just seems to have been day after day of darkness.
Hope you manage to get yourself sorted with the manuals and missing kit parts.
Tony
#9 Posted : 23 January 2020 21:42:59
Pochers instructions are probably the WORST cat kit instructions ever.They are really hard to follow and in many cases the order of construction causes headaches.The CD guides are essential for the trickier Pochers like the Rolls and the Alfas.
Mustang
#10 Posted : 23 January 2020 23:36:59
Here's a link to my Testorossa
http://www.partworkmodel...opic.php?f=39&t=8356
To build:-
#11 Posted : 24 January 2020 00:27:34
Wow.Amazing job.
greyhawk
#12 Posted : 30 January 2020 17:12:07
Paul Koos instructions are worth every penny. He put a LOT of effort and thoughts into these and they are immensely helpful.
Mustang
#13 Posted : 01 February 2020 22:52:36
Hi guys I have another question.
Just regarding the wheels, I'm going to have to rebuild these as there falling apart and one is in bits.
I don't have the jig for these so I was wondering if anyone has one and could post some photos so I can see if I can make one using one of the prebuilt wheels as a reverse jig.
I've built the Jag and the wheels on that I found easy to build.
Any help would be appreciated.
To build:-
#14 Posted : 02 February 2020 02:08:07
Apparently the Pocher wire wheels are a nightmare to assemble.The fit isnt great and the jig never worked well.Modelmotorcars makes a resin set oh wheels so you dont have to stack all those plastics rings
Mustang
#15 Posted : 02 February 2020 09:51:54
Hi Carl,
Yes I've seen modelmotorcars but at £40 each for the Alfa and £45 each for the rolls that's £240 + £225 total £465 plus you still need to use the pocher wheel jig in order to build them.
I'm happy with how the pocher wheels look but just need to rebuild them, if I can't make a jig then I'll buy a set from eBay.
To build:-
#16 Posted : 02 February 2020 18:14:01
I have the Pocher sedanca kit.I am not sure if the jig is the same for each car, but I can take a look at that and 3d design one and email you the .stl if you like. I am sure it is a pretty simple design.
Mustang
#17 Posted : 02 February 2020 22:47:21
Hi Carl, thanks for the offer.
I've spent the day stripping down the Alfa into sub sections, there's a lot of bits missing and some of the wheel bits like the break units.
So I'm going to have to at some point buy a set of the plastic parts which include the jig.
To build:-
Mustang
#18 Posted : 10 February 2020 20:08:39
So I've finally managed to work out what I believe is missing from the Alfa, unfortunately it's a lot and not sure if it will be worth looking for the parts but I'll keep thinking about it.
I've contacted both pocher.net and paul koo about the bits, pocher.net recon it will cost more to get the missing bits then to buy a complete kit.
So at the moment it's a no no 😞
So at some point I'll strip the Merc or Rolls down and see what's what.
To build:-
#19 Posted : 11 February 2020 00:16:16
Well that sucks.Can you at least part it out and get some money back from it?
Mustang
#20 Posted : 12 February 2020 19:39:49
Hi Roy,
Been trying to reply to your pm's but your inbox is full and the system won't allow me to do so.
If you read this hopefully I can contact you again, and once read you can delete this post.
Anyway hopefully talk to you soon.
To build:-
Guest (7)
2 Pages 12>
This page was generated in 0.214 seconds.
