80 Pages «<6768697071>»
Sticky Wickett
#1361 Posted : 17 January 2020 17:50:10
birdaj2 wrote:
Really nice work Phil.
Your attention to the small details is breathtaking.
Tony
Thank you very much Tony!
Phil W.
Sticky Wickett
#1362 Posted : 17 January 2020 17:52:48
Markwarren wrote:
Another amazing update Phil. Hope you’ve got the champagne ready for its maiden voyage.Love Drool
HahahaLOL Thank you Mark. The champers is ready and gathering dust by the day!Flapper
Phil W.
Sticky Wickett
#1363 Posted : 23 January 2020 22:32:54
More progress on the aft torpedo compartment. I focused on adding detail to the torpedo tube, testing for fit as i went.
See attached photo of the torpedo tube completed, painted and ready for final fitting.
Sticky Wickett
#1364 Posted : 23 January 2020 22:33:57
The piston I built in a previous post could now be painted.
Sticky Wickett
#1365 Posted : 23 January 2020 22:34:39
Both aft torpedo tube and piston fitted in place.
Sticky Wickett
#1366 Posted : 23 January 2020 22:35:42
That concludes this weeks update. More to follow next week.
Thanks for looking in, have a great weekend and happy modelling.BigGrin
Phil W.
#1367 Posted : 24 January 2020 14:12:23
Excellent work as usual Phil. What a difference the torpedo tube makes.Love Love Drool
Sticky Wickett
#1368 Posted : 24 January 2020 14:15:04
Hi Mark, yes it certainly does, but i couldn't of fitted it until all those other pipes and valves were in as there was no room.
Phil W.
#1369 Posted : 24 January 2020 23:38:24
Torpedo compartment is filling up beautifully with detail and is worth all the effort you're putting into it... Looks amazing Phil....Love Love Love
Sticky Wickett
#1370 Posted : 30 January 2020 09:01:01
Thank you very much Alan!
Phil W.
Sticky Wickett
#1371 Posted : 30 January 2020 09:06:52
Good morning from 'The Dockyard'.
This week has seen me build a depth gauge / speed indicator, located next to the aft torpedo tube.
First job was to find a suitable image, which I sourced from the U995 dvd. I cropped the image in photo editor to remove all unwanted background before importing it into power-point where I could resize to the exact dimensions I was looking for.
The attached image shows the original photo, cropped, prior to resizing.
Sticky Wickett
#1372 Posted : 30 January 2020 09:09:08
The next photo shows the printed image after resizing in power-point. Don't tell work I used their colour printer!!Flapper
Sticky Wickett
#1373 Posted : 30 January 2020 09:10:33
I then began to make the instrument box that displays the depth and speed. The attached photo shows the front fascia being made.
Sticky Wickett
#1374 Posted : 30 January 2020 09:11:43
Fascia complete along with the instrument box. Both measure 8.0mm long, 4.0mm wide and 5.0mm high.
Sticky Wickett
#1375 Posted : 30 January 2020 09:14:34
I then cut out a piece of transparent plastic sheet to suit the box dimensions. I glued it to the back of the fascia and glued the paper gauges to the other side. All of this was fixed to the main body.
Sticky Wickett
#1376 Posted : 30 January 2020 09:16:21
I then added a small control box to the side of the depth / speed indicator and also brackets and electrical wire.
Sticky Wickett
#1377 Posted : 30 January 2020 09:17:57
From another angle.
Sticky Wickett
#1378 Posted : 30 January 2020 09:19:08
Painted. I also added a small, brass plaque to the control box as well as painting it's handle in matt black.
Sticky Wickett
#1379 Posted : 30 January 2020 09:20:12
From another angle.
Sticky Wickett
#1380 Posted : 30 January 2020 09:21:29
Depth / speed indicator completed, painted and fitted.
This page was generated in 0.514 seconds.
