Joined: 08/02/2016 Posts: 159 Points: 520 Location: Česká Republika
Getting to this model was very difficult and lengthy, but I finally got one piece from the publisher of this kit and I will accompany you throughout the construction. Hopefully you will enjoy this topic and would like to watch it.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,868 Points: 17,756 Location: ipswich
I'm sure that this build will be very popular. It will be great to follow.
Construction begins. I sorted out the parts for the construction of the engine and started to modify both the parts and mainly the surface. Most of the engine parts were designed by the manufacturer in a luminous silver color, but this is very inadequate for me. I sprayed the parts with matt black paint Tamiya and after thorough drying all the main parts, brushed, dust paste steel from Uschi. I lightly soiled the engine parts and for me the result is as I had imagined it.
Hi Ruda, can't wait to see this build progress. Such a rare and wonderful looking kit. I'm very jealous. Malc.
Looks amazing, very well done.... Regards Alan
Greetings colleagues and thank you very much for your reaction to the construction. The construction of the model is not easy and the model I build is being modified. Modified are both parts and mainly surface coloring. Parts of the kit are damaged by dividing planes and ejectors. Thank you for watching this topic and this building.
 Rank: Amateur Level 1  Groups: Registered
Joined: 22/03/2011 Posts: 30 Points: 108 Location: UK
Hi Ruda,
I finished mine at Xmas after a lengthy procurement via my pal in Florence, and 3 excuses for a holiday to pick it up!
I’m sure you’ll agree, the parts are pretty much all there, but you need to repaint them to get it to look authentic.
I covered the monocoque in Bare Metal Foil, and am pretty happy with the result overall. Unfortunately, the body decals are mostly pre-fitted and are dry transfers, so I’ve had to put up with the supplied paint - however, careful polishing with Tamiya Compound around the decals gives a sufficiently shiny finish.
If I can work out how to post pics from an iPad, I’ll do so, meanwhile, go for it and keep posting!
DBP 😀🇮🇹
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,416 Points: 22,558 Location: Northamptonshire, England
Excellent work, will be following with interest. Mark Regards Markwarren (Mark) Admin
Very impressive work. Can't wait to see how this turns out. Roy.
I modified the battery, added a few cables and mainly added a sticker on the battery, which kit does not offer and it was necessary to make it. I connected the fire partition and the battery with the engine, connected the hoses and wiring. All the parts of the middle part, today, ,, bathed ,, in lye, sprayed with a black base and everything was sprayed with Alclad II.
Joined: 25/12/2019 Posts: 218 Points: 659 Location: Manhattan, NY
Looking great so far! -Dustin
“Details make perfection, and perfection is not a detail.” -Leonardo Da Vinci
Currently Building: Porsche 2.7 RS
Currently Collecting Jaguar E-Type, Ferrari F40, Ferrari 250 GTO, Lamborghini Miura, Ford GT40, Ecto-1, Japanese Zero, Porsche 917, Lancia Stratos
Beautifully done... Can see this is going to turn out to be something special.... Regards Alan
Beautiful start, looks amazing. Mark Regards Markwarren (Mark) Admin
