X-Wing directions error!! Testing the electronics Options
admin
#1 Posted : 13 February 2020 19:19:47
Hi All,
Please note the following!
“Circuit Board Testing
Issue 72 of the magazine states that the functions can be tested on the X-Wing. This is not correct. In order to test the functionality, the electrical line 20 that comes in issue 74 is necessary in order to carry out the test. Under no circumstances are you to bridge the slot 20 and to wait for issue 74 as this will result in the board becoming inoperative and burnt out.
Be aware that no replacement boards will be given should you try this.”
This page was generated in 0.086 seconds.
