Lower wale setting out dimension Options
goddo
#1 Posted : 20 February 2020 11:13:53
I am certain that this topic has been discussed on numerous occasions previously but I cannot seem too find the answer using the "Search" button. My apologies in advance for a repeat question.
In the Official Build Video of Stage 42 (at around 9.30 minutes) we are told to set out the top rail of the lower wale 20mm below the underside of the upper wale. The magazine however, shows that this dimension should be 12mm on page 240 of Pack 5.
Could someone please enlighten me? Thanks.
Chris
goddo attached the following image(s):
#2 Posted : 20 February 2020 11:58:48
Hi Chris, this is actually an error in the narration. If you look at the attached pic, a still of the mark made for the setting of the wale. You will see here that the mark made is at the 12mm point and not 20mm as stated in the voiceover....
Hope this helps.
goddo
#3 Posted : 20 February 2020 12:08:36
Morning Alan and thank you for clearing this up.
Funny, when I wrote the original query, I was thinking that I should go back and pause the video to see if it was indeed 12mm.
That's great. I can move on now.
Chris
This page was generated in 0.030 seconds.
