2 Pages 12>
Al's Aventador build Options
#1 Posted : 24 February 2020 13:57:38
I bought this Pocher kit a few years back and made a start on the engine block. However due to an impending house move it was packed up and forgotten about for while. Since then many other builds have come and gone and now it is time to get this built.This will be built pretty much out the box although there will be some paint used here and there.
The main block and gearbox has been assembled and the hideous Pocher grey plastic has had a coat of primer and aluminium paint applied whilst the rocker covers have had some matt black to tone them down.
andali15
#2 Posted : 24 February 2020 14:31:57
Impressive start Al. Will follow with interest. Andy.
#3 Posted : 24 February 2020 14:34:33
It's a great kit. I built it too a few years back.
There's tons of scope to upgrade it and add the various missing parts.
Enjoy the build.
Roy.
#4 Posted : 24 February 2020 16:16:51
Look forward to seeing how this turns out Al, will be following.....Cool Cool .. Good luck with the build....
#5 Posted : 24 February 2020 16:28:28
Thanks gentsBigGrin
Not taken loads of photos on this but have assembled the cockpit cell,no issues but found the seats were a bit tough to mount on the floorpan.A good bit of planning from Pocher is that they supply parts for both left or right hand drive configurations.Also added more engine parts and wiring as well as got it mounted into the rear subframe along with the exhaust assembly.Also made a start on the front sub frame and steering/suspension assembly.Finally I mounted the rear subframe to the cockpit and fitted the rear suspension rods/wishbones.
#6 Posted : 24 February 2020 17:14:23
nice job
CaptnBirdseye
#7 Posted : 24 February 2020 20:15:20
Rank: Superelite
BigGrin Looks good Al ThumpUp
Very jealous Love
Regards Gray
#8 Posted : 25 February 2020 16:07:02
Thanks Carl/Gray.
Have now got the front subframe on and the windscreen and wipers fitted. The kit also supplies wipers and blades to cater for right hand drive builds. The rear tailgate is next to be constructed before assembling the rear bumper and light unit with the spoiler and rear body parts.The inner side wings were added and the tailgate fitted before the whole assembly was added to the main chassis assembly.The quarterlight windows and trim was attached and the cooling scoops added for the last picture.
#9 Posted : 25 February 2020 16:10:53
Wow you are really moving along with this.I think Roy did a modification of this kit so you could easily lift the rear end off to show the engine?
#10 Posted : 25 February 2020 16:18:43
Thanks Carl,
I've had a few days off so been cramming as much modelling in as I can getBigGrin I have another Aventador in the stash which I intend to spend a bit more time on at a later date and utilise Paul Koo's dvd as well as a colour change.
#11 Posted : 25 February 2020 16:39:23
Altering the rear to be fully removable is quite easy but it's not on the Koo DVD.
My build is here somewhere (I think)
If not, I'll post a separate page about 'how to do it'.
You're really moving ahead on this. Great stuff.
Roy.
#12 Posted : 25 February 2020 17:16:45
Spal wrote:
Thanks Carl,
Cool.Did you get the detail set by Tomaso ?
#13 Posted : 25 February 2020 21:08:59
Very nice work Al, certainly coming along very nicely.Love Drool
kpnuts
#14 Posted : 25 February 2020 22:13:49
Looking great
#15 Posted : 27 February 2020 00:31:49
Looks like another great build from you Al, all looking good.....Drool Drool
#16 Posted : 27 February 2020 09:45:19
Looks a great kit to build Al,looking forward to the next post.
Trev
#17 Posted : 27 February 2020 17:46:52
Roy.
Cheers Roy, I vaguely remember you building this way backBigGrin
#18 Posted : 27 February 2020 17:48:31
darbyvet wrote:
Spal wrote:
Thanks Carl,
No i didn't, i seem to recall it was rather expensive although very nice.
#19 Posted : 27 February 2020 17:50:11
Thanks for looking in Ken, Mark, Alan,TrevBlink more up soon.
#20 Posted : 27 February 2020 18:04:25
More of this now done.Built the headlamps up, very fiddly but look great once done and fitted.Also connected the bonnet and hinges and then fitted the pe mesh to the front using the hot screwdriver to melt the locating pegs a little rather than using glue as per instructions.Having moved on to construct the doors and mirrors, the doors were then mounted onto the car in another fiddly operation which took several goes atLOL.The front body section was then fitted and secured from underneath.
2 Pages 12>
