16 Pages «<45678>»
MWG build diary of the iconic 007 DB5 Options
#101 Posted : 28 August 2011 19:50:25
ISSUE 33
Hi everyone no 33 shows the two parts of the passenger seat ejection system :-
#102 Posted : 31 August 2011 20:57:07
ISSUE 34
This time we have different parts:-
1) Rear seat parts.
2)Spring for seat ejection
3)Clip for seat ejection
Here are some photos :-
#103 Posted : 31 August 2011 20:59:46
And here is a little mouth watering photo of some specs as a treatCool Drool
#104 Posted : 07 September 2011 08:32:41
ISSUE 35
At last the first major part, the floor plan, many of the parts we have received fit int this Part:-
#105 Posted : 07 September 2011 08:34:47
I will be enhanceing this part by adding carpet,but more about that laterDrool
kryten2b
#106 Posted : 07 September 2011 10:03:52
I look forward to seeing the results ThumpUp
What do you plan to use for the carpet?
Well spin my nipple-nuts & send me to Alaska
Current Builds:
McLaren MP4-23Finished
007's Aston Martin DB5Finished
Millennium Falcon
R2-D2
BTTF Delorean (Maybe)
#107 Posted : 07 September 2011 10:12:04
Hi mate,
A black or grey wallet cut up and the suede side uppermost (brushed with a suede brush) and a small square cut and suede part down where the heels of your feet would go, am I making sence?Blink Plus line the weapons tray.
kryten2b
#108 Posted : 07 September 2011 10:34:55
Ah, yes i understand - on the other forum i believe they refer to that as 'Australian Leather' LOL
I will probably fo with the dollshouse carpet option - when i eventually catch up
I should think lining the weapons tray will be fiddly - good luck with that & watch the blood pressure BigGrin
Current Builds:
Millennium Falcon
R2-D2
#109 Posted : 09 September 2011 18:51:40
Thanks for that mate?BigGrin BigGrin Cool
#110 Posted : 11 September 2011 19:32:32
Here is the outcome of my visit to the Dolls House Fair
No one, Grey carpet for inside the car and to line the weapons tray
#111 Posted : 11 September 2011 19:34:23
The second item is Strong tape to be used as seat belts
#112 Posted : 11 September 2011 19:36:10
The third item is a glass jar to use as a washer bottle
#113 Posted : 11 September 2011 19:38:52
And the last item is Jelly water, to put in the waher bottle and it will look like screen wash when a little blue colouring is added.
Thats all for nowCool
#114 Posted : 11 September 2011 21:40:52
Well its time to press on with some building
The floor panel is now the place to start,the first job is to fit the pedals:-
#115 Posted : 11 September 2011 21:46:41
The throttle pedal on the original car was silver, and so I painted it with Humbrol Metallic paint, I am pleased with the result, when its dry I may apply a second coat before I fit the carpet in left and right front and back floor wellsBigGrin Cool
#116 Posted : 11 September 2011 21:49:11
It will need a second coat, the carpet will go straight through under the pedals, thats all for nowCool
kryten2b
#117 Posted : 11 September 2011 22:59:07
Looking good MikeThumpUp
One word of caution though - I have heard others mention that those pedal wires are a bit flimsy, so be careful when carpeting, otherwise you'll be reaching for your soldering ironCursing
Current Builds:
Millennium Falcon
R2-D2
#118 Posted : 12 September 2011 10:07:28
Hi Jerry the second coat of mettalic is onCool
#119 Posted : 12 September 2011 10:10:18
Hi Jerry Re the wires on the pedals, they come out of the back of the assembly, they are delicate but not flimsy, and do not come in contact with any part of the carpet.
I will post a Photo
#120 Posted : 12 September 2011 10:13:58
Guest (19)
16 Pages «<45678>»
This page was generated in 0.419 seconds.
