Lock Tight for screws? Options
andali15
#1 Posted : 30 March 2020 17:33:49
I’ve finished my build JonD but did not see the necessity to use a screw lock. The model will not be played with just displayed but if you consider using something make sure it can be disassembled, some products allow this. On my Millenium Falcon I did use Thread Lock Blue, a medium strength that allows disassembly of threads. Good luck with your build Andy.
This page was generated in 0.086 seconds.
