Joined: 11/04/2018 Posts: 37 Points: 123 Location: Michigan
I am working on the main topmast and requires that the lower section of the mast be octagon shaped. I tried several times and I can't get to come out right . Is there a technique I could try.
Not sure if you did this but file the dowel into a square first and then flatten the corners.
No I did not try that I will give it a shot. Thanks
