Planking shortage Options
halfpint
#1 Posted : 13 April 2020 11:51:14
Rank: Beginner Level 1
re visited the model (HMS Victory) after spending some years abroad working, ive decided to re do one side of the hull due to warping etc from poor storage, I'm seriously short of planking strips now, do I have to re order the magazines containing the planks (expensive route), or is there some where i can purchase the planks and pins,
I would imagine there are quite a few abandoned projects out there maybe that would help out
thank you in advance BigGrin
z8000783
#2 Posted : 13 April 2020 12:00:15
Groups: Unapproved
Have you looked here?
Lime Planks
halfpint
#3 Posted : 13 April 2020 12:14:35
Hi John,
looks like thats where i should order, thank you very much indeed, do you know the Victory plank dimensions, as per mm, not particular about the length,
thanks once again
halfpint
#4 Posted : 13 April 2020 12:29:32
John,
Im thinking 5x2mm?
#5 Posted : 13 April 2020 12:54:09
halfpint wrote:
John,
Im thinking 5x2mm?
You are correct.
Stage 21 in the instructions confirms that.
halfpint
#6 Posted : 13 April 2020 12:58:46
great, nice to get second confirmation, unfortunately the site john sent does not have them in stock, so will keep searching, I,ve mailed them to see if they can help though
while I,m waiting i think i will just browse back over the issues i have completed to re check specs etc,
thanks again
z8000783
#7 Posted : 13 April 2020 13:02:12
Groups: Unapproved
halfpint wrote:
John,
Im thinking 5x2mm?
Yes, that's it.
Have a look to see if there is any other wood you might need while you are ordering. For example, I found I needed 2 pieces for the poop deck bulwark caps, I can't remember why, probably a mistake I made with cutting. But I ordered a long length from here to cover it.
You might also want to tell them that it's OK to break the metre lengths up for easier packaging.
halfpint
#8 Posted : 13 April 2020 13:10:49
I will John, awaiting a reply, hopefully I can source it, so hard to get really,
thank you for the advice, and gonna def do that browse rather than jumping in the deep end when i first got the project, my eagerness was soon tempered
gingerale75
#9 Posted : 13 April 2020 18:11:03
Hi,
I have some leftover 5x2mm strips and lots of pins.
If you wish I can send it to you.
Happy building!
Laszlo
Finished builds: HMS Victory, HMS Victory Cross-Section
halfpint
#10 Posted : 15 April 2020 16:19:45
how many strips do you have?, i reckon I'm short probably enough to complete 4 inches each side, ....put it this way, i'd prefer to reimburse you than wait weeks for a shop to get them or even post,....thank you so much
gingerale75
#11 Posted : 15 April 2020 17:27:46
Hi,
I have approx 50-60 strips.
Drop me a PM with your address and I'll post it as soon as I can.
Happy building!
Laszlo
This page was generated in 0.806 seconds.
