3 Pages 123>
GWH F-15C MSIP II by DaDokta Options
DaDokta
#1 Posted : 23 April 2020 12:02:03
After completing my Vic i`ll go for something completely different.
It´s been about 20years that i built a plastic model - at that time i just had some brushes, a bad plastic glue and just a few colours that were available.
So one can say i have no experiance regarding modern plastic modelling.
But i`m eager to learn all those "new" techniques, especially airbrushing (my wife got me one as a christmas present!)
So let`s give it a go!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
DaDokta
#2 Posted : 23 April 2020 12:04:16
Here´s the kit and Eduard`s PE set.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#3 Posted : 23 April 2020 12:06:45
And here are some pics of the ejection seat.
I made some cushions out of blue tack and used some PE-parts.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Kev the Modeller
#4 Posted : 23 April 2020 19:45:38
That's a nice start on the ejector seat Walter, looking good with some nice dry-brushing technique to bring out the detail, and great to see that you've scratchbuilt some seat cushions too - well done.
Great to see another aviation build on the forum, I will be following your progress! Cool ThumpUp
Kev.
Per Ardua Ad Astra
#5 Posted : 23 April 2020 22:53:26
Good luck with your new venture Walter, am sure you'll quickly learn all the new skills you need to end up with a very successful build....Cool Cool .. I'll be following with great interest....Cool Cool
DaDokta
#6 Posted : 24 April 2020 12:28:00
Thanks Kev and Alan!
Well i must say - as it stands now - i spend more time with cleaning my airbrush and remove blockage than actually painting parts :)
We`ll see how this works out!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Kev the Modeller
#7 Posted : 24 April 2020 16:10:15
Hello Walter,
If your airbrush is constantly clogging up, you've probably got the air pressure too low or the paint too thick, or both? Try thinning your paint to about 50/50 paint/thinners and setting your air pressure (if you can) to about 15-20psi? That should help.
Difficult things to master, airbrushes, but once you understand how to set them up and mix the paint correctly, you'll never use a brush again apart from painting small details or dry brushing!
Kev.
Per Ardua Ad Astra
DaDokta
#8 Posted : 24 April 2020 16:28:54
Thanks for the advice, Kev!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
bfam4t6
#9 Posted : 24 April 2020 19:13:53
Publisher Medal: Featured Build of the MonthBuild-Diary Medal: Build-Diary Medal of Honour
Nice start! I still need to learn how to airbrush myself. Good luck!
-Dustin
“Details make perfection, and perfection is not a detail.”
-Leonardo Da Vinci
Currently Building:
Porsche 2.7 RS
Currently Collecting
Jaguar E-Type, Ferrari F40, Ferrari 250 GTO, Lamborghini Miura, Ford GT40, Ecto-1, Japanese Zero, Porsche 917, Lancia Stratos
#10 Posted : 24 April 2020 20:56:03
good luck Walter with your new build I do agree with Kev's advice regarding Airbrushing.
Trev
ps: don't give up on the airbrushing
#11 Posted : 25 April 2020 09:50:55
Nice start Walter. Will be watching with interest. Love
#12 Posted : 26 April 2020 13:43:39
Great start Walter, look forward to seeing your progress with this.
AL
DaDokta
#13 Posted : 28 April 2020 13:57:36
Thanks guys!
PE was added to the cockpit and wheel well parts.
Then the next spray job had to be done!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#14 Posted : 28 April 2020 15:49:32
Hi coming along well,will be following your progress. Cheers mick. BigGrin
DaDokta
#15 Posted : 29 April 2020 11:20:38
Detailed parts of the cockpit and the avionics bay:
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#16 Posted : 30 April 2020 11:12:35
Cockpit and avionics bay assembled.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#17 Posted : 01 May 2020 08:58:35
Very detailed work there Walter and looks great too.... very well done....Drool Drool Drool
#18 Posted : 01 May 2020 19:47:51
Some very nice detailed work going on. Great job.Love Drool
Kev the Modeller
#19 Posted : 06 May 2020 17:03:10
Nice work on the cockpit Walter and considering this is not your normal genre or kit material, I think you're doing a very good job!
Well done, keep it up, will be watching. Cool ThumpUp
Kev.
Per Ardua Ad Astra
DaDokta
#20 Posted : 13 May 2020 09:22:15
Thanks guys!
I`ve been working on the exhausts lately.
This pic was my template.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
3 Pages 123>
This page was generated in 0.349 seconds.
