80 Pages «<7677787980>
Garth
#1541 Posted : 16 April 2020 10:53:42
Hi Phil,
Another awesome update. Fantastic attention to detail.
Hope your repairs are coming on smoothly.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Sticky Wickett
#1542 Posted : 24 April 2020 11:53:02
Good morning from 'The Dockyard'.
Well I've been busy working, interspersed with sporadic model making sessions. Progress has been slow but steady as I concentrate on the repairs.
See the attached photo showing the replacement part that I will have to fit.
Sticky Wickett
#1543 Posted : 24 April 2020 11:53:54
The rivet strips on the affected parts were carefully removed and labelled.
Sticky Wickett
#1544 Posted : 24 April 2020 11:55:41
The next step was to tentatively remove the melted parts without causing further damage. So I proceeded to remove small sections at a time causing a great deal of mess!Flapper LOL
Sticky Wickett
#1545 Posted : 24 April 2020 11:56:37
The slitting saw attached to the Dremel made light work of the thicker plastic parts!
Sticky Wickett
#1546 Posted : 24 April 2020 11:59:11
Gradually opening out a section to fit my replacement part.
Sticky Wickett
#1547 Posted : 24 April 2020 11:59:44
From another angle.
Sticky Wickett
#1548 Posted : 24 April 2020 12:01:21
Replacement part now sitting in it's correct location. Not fixed or glued at this stage. A lot more work involved such as filling, pinning, fettling and filing.
Sticky Wickett
#1549 Posted : 24 April 2020 12:02:12
Plenty of gaps to keep me busy with filler and sanding!LOL
Sticky Wickett
#1550 Posted : 24 April 2020 12:03:13
Rear view.
Sticky Wickett
#1551 Posted : 24 April 2020 12:03:43
Side view.
Sticky Wickett
#1552 Posted : 24 April 2020 12:08:57
That concludes this update. By the time I post my next update I hope to have it glued and pinned in place and all filler work completed. Depending on progress, my update will either be next week or the week after.
Thanks for looking in and stay safe people!
Phil W.
Kev the Modeller
#1553 Posted : 24 April 2020 16:04:38
The restoration looks like it's all going to plan Phil, glad you were able to save this fabulous build and I wish you every success in moving forward with it.
Well done! ThumpUp
Kev.
Per Ardua Ad Astra
#1554 Posted : 25 April 2020 09:42:19
Well done Phil, looks to be going to plan and back up and running in no time. I bet there was a few hold your breath moments though. Great work.Cool ThumpUp
#1555 Posted : 25 April 2020 22:55:41
Didn't think you'd let this set back stop you Phil, can see the repair work is coming along beautifully...Drool Drool Drool … Great to see you getting back on track.... well done....Cool Cool
#1556 Posted : 26 April 2020 15:31:47
Hi Phil, BigGrin
WTG with the start of the repair. I`m sure I would not have been brave enough to wade in with a dremel saw, Blink Blink more likely a sharp blade and then taken three months.LOL LOL
Wishing you well with the rest of the repair job that`s looking spot on.Cool
Garth
#1557 Posted : 29 April 2020 09:35:00
Hi Phil,
Repairs coming along nicely.
Kind regards,
Garth
Sticky Wickett
#1558 Posted : 09 May 2020 10:44:44
Good morning from 'The Dockyard' and i hope you're all well?
More progress has been made on the hull repairs. I spent a bit more time ensuring that the replacement part would fit correctly. Far easier to write these words than accomplish!LOL The idea being that it fits with all edges aligned and no force required to achieve that.
The next step after this was to drill out all of the free flood holes with a 0.8mm drill bit and dress them with a needle file. This took about 6 hours in total. See attached photo.
Sticky Wickett
#1559 Posted : 09 May 2020 10:57:29
The next step was to fit packing pieces, which I will use to fix the part too. There are several of these packing pieces and I would fit one, then file it to size by constantly checking that the replacement part aligned as it did before. If it sat too high, I would know that packing piece was sitting too proud. It was far easier to fit one at a time, which narrowed down which packing piece to work on.
See attached photo showing three packing pieces fitted, indicated by arrows. They were all made from MDF cut offs, fixed with PVA glue and left to dry overnight before filing them. By fitting one at time, it took several evenings to complete this stage.
Sticky Wickett
#1560 Posted : 09 May 2020 10:58:38
More MDF packing pieces, indicated by arrows.
This page was generated in 0.447 seconds.
