Level´s Mercedes Sprinter Options
Levelord
#1 Posted : 28 April 2020 18:52:57
Publisher Medal: Featured Build of the MonthBuild-Diary Medal: Build-Diary Medal of HonourRed Medal: Red Medal
Groups: Registered, Moderator
Hello everybody,
Here I would like to introduce you to one of my projects that I have been planning and building for a year now.
I build one of our company cars as an RC model.
A brother had to use Sprinter (toys) for this. I completely disassembled and cut it, because I only need the driver's cabin.
Next, I had 3D axes made and equipped them with four small geared motors. The cargo hold is a resin cast from Greencast from the Netherlands.
I then cut the load space until the cabin fit well and then screwed the two together.
Then it started ... fill and sand ... until everything fit.
In the spring I could finally start painting.
Then the rear lamps were cast and LEDs were inserted and soldered directly. Now the rear axle was also installed and the vehicle was partially assembled again. Lights and indicators were now also used in the front of the headlights. The rims are also 3D printed and the tires are from Fischer Technik. The first stickers are on, the others were measured last week.
Sequel follows...
Der gesamte Baubericht und alle Fotos unterliegen dem Urheberrecht. Verwendung außerhalb dieses Forums bedürfen schriftlicher Genehmigung. © Levelord
@work: X-Wing,Dodge Charger, MIG-29
Completed: McLaren MP4-23, Hummer H1, RedBull RB7, Easy Rider Bike, Jaguar E-Type, Porsche 911, Ferrari F2004, AMG DTM Mercedes, Ford Mustang, R2-D2, C57, Modellbahn,Rossi Bike,VW Käfer 1303,VW T1 Samba Bus
mwb
#2 Posted : 28 April 2020 22:03:29
What a unique subject to model. Very interesting. Well done sir.
mwb
andali15
#3 Posted : 29 April 2020 08:33:05
“ White Van mans “ dream model I would think. Brilliant adaptation of a well known vehicle. Andy.
#4 Posted : 29 April 2020 10:29:04
That's a great project. Hard to imagine it began as a toy.
Looking brilliant. Be good to see a video clip of it actually moving at the end.
Roy.BigGrin
This page was generated in 0.197 seconds.
