After receiving issues 3-6 we are back on back order.
Anyone have any idea when issues 7 and upward are going to be back in stock?
Is this delay due to Covid?
A lot of disruption is being caused by Covid but hopefully this won't go on for too much longer.. All we can ask if for members to be patient.... Regards Alan
Has anyone received any information on when the back ordered issues are going to be in?
Other then receiving the first 3 issues on time, the rest has been delayed , delayed , delayed with no info from Deagostini.
Any info would be appreciated.
Thank you
gmbnj wrote:Has anyone received any information on when the back ordered issues are going to be in?
Thank you Check your PM’s! I need a bit of info from you. Nothing’s backordered.
Any updates on issue 10 and so on ? Been months with no shipments.
Have you contacted CS? Most everyone is getting parts, so I suspect something else is amiss. Unfortunately, I have zero access to accounts, and it’s proven to be far more effective if CS is contacted for issues such as this.
If you’re still meeting a roadblock, let me know.
Best,
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,829 Points: 17,639 Location: ipswich
Which kit is being discussed here? Unless I'm being dim, I can't see any mention.
roymattblack wrote:Which kit is being discussed here? Unless I'm being dim, I can't see any mention. I believe it's for Air Force 1
Dodge Charger and CS just says backorder with no re stock date.
gmbnj wrote:Dodge Charger and CS just says backorder with no re stock date. Let me find out what’s going on with this.
Thank you that would be great!
