 Thanks Mark Just looking forward a bit to Stage 53-6 Quote” Have the 1mm brass wire (Stage 43) and the right side of the cockpit made in Stage 44 ready. Cut and shape three pieces of brass wire like those shown in the photograph (look at the following step to see where they fit” Nothing like precise instructions with accurate dimensions
Hi Gray, It's great to see your build taking shape I know the effort you have put in, and it is a lovely kit to build there should be more on the Forum, I still have to finish mine but with a house move it just got put aside. Great work Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
 Hi Trev, thanks for looking in. It is a great kit on the whole, but compared to what’s on offer these days from the likes of Hachette, just a little dated. Don’t get me wrong, if I could marry the engine detail and electrics package from Hachette with the wooden body design and metal skin of this one (no panel gaps!), this would be my perfect model  . At least this one has the retractable undercarriage and rotating prop. tf64 wrote:Hi Gray, I still have to finish mine but with a house move it just got put aside.
Great work
Trev That’s always a problem moving house, but I hope you get back on yours soon. Regards Gray
Happy VE Day folks Due to lockdown, there's not much celebrating going on so thought i'd spend some more time on my Spitfire (apt don't you think?). Here are the last steps for Stage 53. Engine bay support frames are sanded, nose re-enforcements fitted, and brass wire bent to shape and glued into position in the cockpit. I've actually used the 1.5mm wires, but don't think it matters (artistic licence)  . CaptnBirdseye attached the following image(s):
 Hi All, Did a small update today, and finished Stage 54, the engine cover. It's much easier to build it situ, so as to get the correct shape and making it sit perfectly on top of the engine frame (thanks again for the tip Delboy!) CaptnBirdseye attached the following image(s):
Good to see you forging ahead with this one. I`m happy to help where I can and all is looking good to date. Only thing is that you are rapidly heading to pass where I`m at with my build. There are six covering plates to fit between stages 59 and 63 which I have not done, but when they are done I`ll be complete to stage 63.  When? don`t know. I`m still open for questions if needed and I`ll give my best advice. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Gray, All looking good and in alinement nice update. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Excellent progress Gray, all looking very neat and tidy.. Your work always looks so precise and very well presented.... Very well done.... Regards Alan
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,307 Points: 22,228 Location: Northamptonshire, England
Very nice work Gray, all looking very good. Mark Regards Markwarren (Mark) Admin
