Packing pieces made of square acetal strip were cut and filed to shape and added to the replacement part. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then drilled 0.8mm diameter holes through the replacement part so they aligned with the packing pieces. The reason for this is so I can pin the replacement part with brass rod once it has been glued in place. Gluing alone doesn't provide enough strength and I have used this technique extensively on this build. The replacement part has to support both prop shafts, propellers, two rudders and two aft diving planes, plus all of their support brackets. Pinning with brass rod means this part will provide a very strong platform to fit all of these extras. See attached photo of a 0.8mm diameter hole being drilled through the replacement part. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Once all the pilot holes were drilled, I deburred them and glued the replacement part to the hull with PVA glue. See attached photo. I will let this dry thoroughly over the weekend before moving onto fitting the brass pins, which i'll detail in my next post. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this post, another to follow next week. Thanks for looking in, enjoy the warm weather today before it gets chilly again and stay safe people! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Nice work Phil, from disaster to a very nice repair job.  You must be feeling a sense of satisfaction. Mark Regards Markwarren (Mark) Admin
Beautifully done Phil and a very well worked out repair job. Pretty soon you'll be back to where you were before disaster struck.... Well done.... Regards Alan
Markwarren wrote:Nice work Phil, from disaster to a very nice repair job.  You must be feeling a sense of satisfaction. Mark Hi Mark, yes, i have now turned a corner and things are starting to look up again. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Gandale wrote:Beautifully done Phil and a very well worked out repair job. Pretty soon you'll be back to where you were before disaster struck.... Well done.... Regards Alan Thank you Alan. Once I had the replacement sitting correctly i began to feel things were on the up. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Well done Phil! I only came across the damage you sustained a few days ago but you've made a wonderful job of putting it right. I know just how you must have felt, when my old Victory got her poop deck 'shot away' in the attic accident I felt the same but its a lovely feeling when you see it come back to 'good as new' again. Now, just keep away from depth charges and heat sources! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Plymouth57 wrote:Well done Phil! I only came across the damage you sustained a few days ago but you've made a wonderful job of putting it right. I know just how you must have felt, when my old Victory got her poop deck 'shot away' in the attic accident I felt the same but its a lovely feeling when you see it come back to 'good as new' again. Now, just keep away from depth charges and heat sources! Robin Thank you Robin! Yes, steering a new course away from all depth charges and incendiaries [grill, kettle and oven]! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Good morning from 'The Dockyard'. Further progress was made on the hull repairs. After the replacement part was glued into place, the next step was to reinforce it by inserting brass rod, cut to length, to act as strengthening pins. I had already drilled the pilot holes as mentioned in my last post, so it was a case of opening them out to the correct diameter of 1.0mm for the brass rod. The attached photo shows the brass rod inserted into one of the locating holes until it 'bottomed out'. I then marked the rod, withdrew it and cut just below the mark so the rod would be just under the surface of the hull when fixed. I continued in this manner until all holes had been drilled out and brass pins fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then proceeded to fill the gaps with Exterior Polyfilla. I let this dry overnight and applied a further mix in places where it had shrunk a little. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I have found that I prefer using Polyfilla on this model for various reasons; its easy to wipe away excess when applying, its easily sanded when dry, it can be watered down, which is handy on smaller areas and it takes paint reasonably well. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Filler work. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
More filler work. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The next job was to attach all of the etched brass rivet strips that I had to remove to conduct the repairs. This is where labelling them made for easy identification and positioning. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
From another angle. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then fitted the rudder mount after cleaning up the edges and removing any flashing or burrs. It was held in place with a couple of bulldog clips. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Rudder mount glued, drilled, pinned and all gaps filled and sanded. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
The last job for this week was to mark out in pencil, all the guidelines for applying the embossed rivet and weld line decals. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Guest (8)
