Wow - another incredible build of this stage coach!Greetings, Walter
Hi DaDokta, thank you for dropping in on my build. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
So I spent the day making up the 3 luggage units, I might make more later Small case and hat box    My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
And the ladies strong box, I went a slightly different way.    The lock didn't come with the kit it was something I found online there will be two side handle but they haven't arrived yet. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
That's really skilful Mustang looking forward to more posts. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Some very nice skilful work. Mark Regards Markwarren (Mark) Admin
Hi guys thanks for dropping by. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Done some more today, still glueing the outer strips so nothing to really show. But I did manage to look at my electronics for the lights I didn't like the idea of a switch inside the compartment and because this will be inside a case when finished I needed something that was particle so remote control Lights on  Lights off  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Stunning work throughout..... Keep posting up those pics, its a beautiful build to follow..... Regards Alan
Very nice work. Mark Regards Markwarren (Mark) Admin
That's a very clever idea Mustang and will show your model of to the best. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Cheers all for dropping in. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Coach unit all done with the sides strips.  Rear luggage rack bottom done, I'll secure the leather bit later.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Handles arrived so the strong box is all finished.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
I've been playing about with what to do with the insides  so after watching The Hateful Eight again I decided on this.  I've cut them all out but not secured them as I'll need to sand down the edges of the window and door frames.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So onto the frame work.  The top sections are easy just remember to shape the edges from outside to inside. The lower sections need to curve so I cut them to the size I needed and then placed them in some hot/kettle water so I could shape them.  Wedged them in and will glue them tomorrow, the instructions tell you to install all the frame work then sand them all down so they sit about 1mm on the outside, I personally find it easier to do each one at a time. So I glued in the four top window frames and then got them to the correct width and I'll do the same with the lower ones, this will also make it easier to install the side frames as you can line them up to the upper and lower frames. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Thats it for the time being, I'll be back once I've fitted all the frames. . My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Great work Ken's the name modeling's the game.
Looking very neat and clean Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
This is looking really great!
