Joined: 13/03/2020 Posts: 8 Points: 27 Location: Svizzera
Hello, after initialization, r2d2 advances a little, moves the head to the right, then to the left and then positions itself in the center, makes a whistle, always flashes quickly purple and remains like this, it does not reach phase 3 with the blue light fixed. The pressed keys do not work, it only makes sounds; connects with the app, takes photos and videos and all recorded sounds. I am using 18650 melchioni 2000 mAh batteries, the only ones I have in good condition. Can you help me? , Hello and thanks .
Sounds like a cable is amiss or not seated correctly somewhere. Look at the troubleshooting guide here. https://forum.model-space.co.uk/...aspx?g=posts&t=32756Mark Regards Markwarren (Mark) Admin
Thanks Mark, but I ask you , these melchioni 2000 mAh batteries can be good for R2D2?
r2d2new wrote:Thanks Mark, but I ask you , these melchioni 2000 mAh batteries can be good for R2D2? Like I said if you are concerned with the burnt patch on the top then don’t use them. The spec on the batteries are the minimum 2000 mAH. Personally, I would ask the seller you bought them from to ascertain whether that is normal and seek his advice before using them. Mark Regards Markwarren (Mark) Admin
Mark, the 2000 mAh melchioni are in good condition, they are the samsung 30 q 3000 mAh that show burn marks and I have never put them on R2D2. Apart from that the melchioni are not among the batteries tested with the robot present in some lists of the forums, I knew that at least the batteries must have 2600 mAh. In case, I would order suitable batteries like the samsung which have been damaged, bye.
