Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Thanks for looking in, appreciate a lot. Makes it worth posting. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
Issue 12, Components in first picture are not used on this part of the build. I found that the gaskets on the outer exhaust pipe flanges were very tight but a little lubricant helped. Alec File Attachment(s): alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
 Coming together we’ll Alec, and thanks for the tip with he lubricant Cheers Gray
Hi Everybody, I'm sorry that I haven't posted recently, some other things get in the way occasionally. This is how it looks now after completing issue sixteen, no insurmountable problems occurred. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
 Wow, can’t believe how far ahead you are Alec! Looks great though Regards Gray
Thanks for looking Gray. I started a bit before you and didn't suffer the amount of delays that you had. It's getting to be a bit of a lump now but I love the amount of detail there is. Some issues don't appear to be very much but it all adds up, lets all hope that Covid 19 doesn't delay things too much out of China but will have to live with it if it does. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
This is issue 17. I wish that the Lambda control unit had be issued a lot earlier in the build, I found that it was unnecessarily awkward to fit and connect the hoses. Amount of detail is impressive as always. I have found that some previously fitted hoses have come off their pins so a tiny touch of adhesive could be a good idea but does need care. Alec File Attachment(s): alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Sorry image wasn't small enough alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
 VERY nice Alec I’m still waiting for packs 12 and 13, which I’m told will be here soon 🤞 Regards Gray
Beautiful progress Alec, a real pleasure to watch it all come together....  …. Keep the updates coming.... Regards Alan
Looks good Alec  look forward to your next update. Al
Thank you for your interest, means a lot. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Gray, Picture alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Hi Everyone, This is issue 18. No insurmountable problems and the detail is superb, very impressed. The clutch and brake levers operate and the throttle rotates and springs back to rest position. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
 Another great update Alec. Good to see those levers work as they should
All looking good Alec, love the detail on this kit..... Regards Alan
Thanks for the comments Alan and Gray. The detail is built into the kit not down to my skill but is fun to put together anyway. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Great to see the detail on these parts  looks good. Al
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,277 Points: 22,138 Location: Northamptonshire, England
Looking very nice, keep the pictures coming. Mark Regards Markwarren (Mark) Admin
Mark and Al thanks for your interest, means a lot. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
