3 Pages 123>
HMS Druid Options
Mustang
#1 Posted : 16 May 2020 22:54:44
I wanted something different and came across this beauty...
One small problem instructions are not in english Cursing
Good job the pictures are ok
To build:-
Mustang
#2 Posted : 16 May 2020 22:56:32
So the parts.
So as you can see this thing is SMALL. Blink Blink
To build:-
Mustang
#3 Posted : 16 May 2020 23:00:17
These are the first parts of the build but the second step, the first step was to build its building base. Yep this models comes with its own base to build on and you need it LOL LOL
So step 1 and 2 together.
To build:-
Mustang
#4 Posted : 16 May 2020 23:04:13
Step 3 was to put 1 and 2 together.
Step 4 build the upper section
Step 5 build the side supports.
Step 6 put it all together.
To build:-
Mustang
#5 Posted : 16 May 2020 23:10:48
Step 7 The ribs, there is a small line burnt into the wood, from what I can make out you have to sand these down to the line.
Step 8-9 Start to build the transom.
Step 10 add more supports.
Step 11 add the upper supports
To build:-
Mustang
#6 Posted : 16 May 2020 23:14:03
Step 12-13 Add more supports again.
Step 14 start to add all the ribs.
They also give you little blocks to add between the ribs, I'll add these once the ribs are in so I can get them all level.
To build:-
CaptnBirdseye
#7 Posted : 17 May 2020 09:30:01
Rank: Superelite
Drool What a great idea for a build!!!
Never seem one like this before. Will follow with interest
Gray
#8 Posted : 17 May 2020 09:39:58
What a super find you've got yourself.. Very different and very interesting....Cool Cool .. Going to enjoy following this one, especially with the great start you've made.....Drool Drool Drool
#9 Posted : 17 May 2020 09:55:40
That looks very interesting. Love looking forward to seeing your next update.Love Love
#10 Posted : 17 May 2020 10:43:17
Hi Mustang, this is a great build and so small follow this one.
Trev
#11 Posted : 17 May 2020 11:25:45
Wow that looks like a neat little build.
Have fun. Cool Cool Cool
Mustang
#12 Posted : 21 May 2020 23:50:28
Hi guys thanks for coming bye.
To build:-
Mustang
#13 Posted : 21 May 2020 23:53:07
Worked out a way to install the frames and the spacers at the same time.
I added a small wedge, so each time I added a frame I removed some of the wedge, so keeping pressure on the ribs while the glue set.
To build:-
Mustang
#14 Posted : 21 May 2020 23:58:48
Step 14 was to install the second from last rib, Step 15 instructed you to remove the unit from the cradle and install the final rib but I added that while it was still in the cradle.
Step 16-17 had you install a piece of planking to the inside, I finally worked out that this was only temporally there to hols the rims together while you sand it all down Blink
To build:-
Mustang
#15 Posted : 22 May 2020 00:00:30
Next we start page 2 which goes back to step 1. hope that makes sense LOL LOL so step 1 of page 2 coming soon.
Don't worry theres only 4 pages to this build Crying
To build:-
Mustang
#16 Posted : 22 May 2020 00:03:31
Hay admin wheres my medal I've hit over 500 posts well it took a while but I have got there LOL LOL please could I have an Orange one BigGrin BigGrin
To build:-
admin
#17 Posted : 22 May 2020 00:04:22
I’ve got this, and I just received the midsection. These are truly brilliant little kit, and a great value for the money!
admin
#18 Posted : 22 May 2020 04:49:55
Ohhhhhh, I dunno....
Sure!
Also, a woodworking trick for you; if you brush a bit of acetone on the laser char, the acetone breaks down the carbon, and makes it super easy to remove.
Mustang
#19 Posted : 23 May 2020 09:02:53
I’ve ordered the mid section, I’m hoping they do a bow section as it would look great if all the parts where put together like one complete ship.
To build:-
Mustang
#20 Posted : 23 May 2020 09:06:26
Thanks for the info on the acetone.
But I sometimes prefer to leave the burn marks, it helps me when sanding down. Once the burn marks are gone I should be ok for the shape.
To build:-
3 Pages 123>
This page was generated in 0.241 seconds.
