anthonyt75 Options
anthonyt75
#1 Posted : 21 May 2020 16:04:00
Rank: Newbie
After assembling the engine it was jamming when the piston was in the bottom position. I dissembled the parts and I noticed that when I turned the shaft the piston rod would seem to get jammed whenever it reached the bottom of the casing. the seemed to be sitting over the piston and was pushed in and properly seated
This page was generated in 0.082 seconds.
