36 Pages «<45678>»
MWG build diary of Nelson's HMS Victory Options
#101 Posted : 04 September 2011 12:20:44
And finaly for this session, I had previously bent the Gallery rear panel useing a weight suspended in a plastic container IT WORKED as you can seeCool
#102 Posted : 04 September 2011 13:49:04
Well done MWG, I found that part of the build a bit tetchy, (no finger nails left) because the gallery parts were so fragile...the lugs on mine were slightly out, nothing a small file did not cure!! You are doing a fantastic job mate!!...keep the picture coming...
ThumpUp
#103 Posted : 04 September 2011 22:04:55
Cheers JonnyBigGrin
#104 Posted : 06 September 2011 20:20:35
Hi everyone, step by step we are coming to the end of ISSUE 40.
Here I have fitted the gallery rear panel no 60 trimming carefully the two gallery supports:-
#105 Posted : 06 September 2011 20:24:26
I then soaked the gallery side panels in hot water for 20 mins, and used this tried and tested method of putting a bend in them where they will wait for 48 hours:-
#106 Posted : 06 September 2011 20:25:48
This is how she looks now:-
#107 Posted : 06 September 2011 21:25:46
Hi Mike
realy impressed with your build, like your idea with the cups to bend side panels BigGrin Keep up the good work. Ian
#108 Posted : 06 September 2011 21:51:39
Thanks mate, I really welcome your commentsCool
alantait
#109 Posted : 06 September 2011 23:02:51
wish i had thought of that about bending the side panelsHuh , they were a pain to hold while the glue setBored even using clamps they still look a bit out but hey its my ship and im happyLOL LOL
current builds
#110 Posted : 07 September 2011 00:02:17
Thats all that matters AlanCool BigGrin
Blackspear
#111 Posted : 07 September 2011 07:34:30
Thats a great tip mike, I am coming up on that stage so I am definately going to try the "MWG cup bending trick" on my side panels....thank you.
#112 Posted : 07 September 2011 08:24:04
Your welcome it works a treat,had to put some other use to my grandchildrens beakersBigGrin Cool
Atholm
#113 Posted : 07 September 2011 16:57:02
Very neat build with some good tips. Keep the updates comming
Happy building
Athol
#114 Posted : 07 September 2011 17:40:05
Thank you AtholCool
Blackspear
#115 Posted : 07 September 2011 18:48:51
ROFL....can just see the grand kids all standing round the Victory and the cups ....pouting!
Tiswas
#116 Posted : 07 September 2011 21:17:46
Nice clean build there Mike. Keep up the good work.
TIS
#117 Posted : 08 September 2011 01:49:05
Thanks TerryCool
StefanDV
#118 Posted : 08 September 2011 14:13:03
Awesome tip on the cups - thanks!
How did you bend the big rear panel?
Tiswas
#119 Posted : 08 September 2011 17:33:28
Coming along nicely Mike, I prefer your planking on the launch, looks better then the thin brass/copper mesh supplied.
A nice smooth finish on your hull planking too. For some reason or other I could not see the last few images? Didn't download.
Will check again later.
TIS
#120 Posted : 08 September 2011 17:43:39
Thanks for your kind comments, Terry much appreiciated.BigGrin
36 Pages «<45678>»
This page was generated in 0.235 seconds.
