2 Pages <12
SMS Scharnhorst Options
#21 Posted : 31 May 2020 22:20:21
Am finding this build very interesting, looks like it will be a lot of fun putting together..... Nice progress Budgie, well done.....Cool Cool
#22 Posted : 01 June 2020 09:25:08
This is looking really interesting.
So looking forward to seeing how this one develops as its such a technical build having to make every part yourself.
Its all looking good at the moment and wish you well with the next stages.
Tony
budgie
#23 Posted : 02 June 2020 20:38:02
BigGrin Thanks for your interest gents, appreciated
Progress so far
Cut vertical slits in the frames and keel, they have a smooth to slack fit which I think is better than a tight fit as that may bend the keel
The frames have been inserted in their corresponding slots so I can start to see a clearer way forward
Double the thickness of all or just a few frames in order to give the "planking" something to stick to
Cut horizontal slits in the frames at 2 or 3 levels in which to insert false decks which in turn will help square everything up before gluing
False deck sizes can be taken from the half breadth plan
Aerial view looking down at the full hull, the lines showing the width of the hull at various depths
budgie attached the following image(s):
#24 Posted : 02 June 2020 20:51:08
Thats taken on a nice shape now you have all the frames in place.
Will your covering (planking) Be card based?
Tony
budgie
#25 Posted : 03 June 2020 08:19:14
Tony
BigGrin Hi Tony
Yes I will be using the 1.5mm card (mountboard) to "plank"
I think it best to stick card to card using elastic bands to hold the strips in place especially at the curves.
Did think about wood but as it is stiffer than card pinning may be required
Pushing pins thru the card frames might not be a good idea they may split at edges
Downside to the mountboard will be when sanding...the white layer will be removed leaving a rough fluffy finish of the fibres
below.
Thinking about using the brown kraftcard to second plank to cover this as nice and thin and cheap
Also thinking about using very thin wood for 2nd planking but as it also will need sealed before painting it may be an unnecessary expense.
Thanks for lookin'
budgie
#26 Posted : 03 June 2020 11:21:08
BigGrin Morning Folks
Checking out the 1/2 breadth plan for making false decks for helping squaring off the frames etc
Hopefully by doing this it will save the monotonous task of putting spacers in between the frames to prevent the card from sagging
The plan shows the waterline and decks from an aerial view
If I want to put a deck in at point iv I cut that shape out and cut slits at the frame positions on the 1/2 breadth and "bulkheads" and just slide them in Cool
The plan also shows the shape around the "gunports" which is good as I was a bit concerned realising it was not a square hole
Thanks for lookin'
budgie
#27 Posted : 26 June 2020 06:34:31
BigGrin Hi Folks
Not posted for a while but just to let u know I haven't given up AGAINFlapper Flapper
I dived straight in to cutting out the false decks to act as support for the frames and "planking"
7 1/2 decks each side
I cut out the slots where the frames were marked on the 1/2 breadth plan and tried to slide them in to the frames
Cursing Didn't fit Cursing
I had stupidly assumed that as the sheer plan and 1/2 breadth plan came on the same sheet that the distance between each frame would be the same
Comparing the plans there is a 4mm difference between frames 2 and 3 which have thrown the rest of my slots out
Which one to follow the sheer or 1/2 breadth planConfused
Cool After spitting my dummy out I am restarting the false decks taking measurements this timeLOL LOL
#28 Posted : 26 June 2020 10:24:09
Glad to hear you are keeping at it.
Nothing more disappointing than getting a stage nearly complete and it then reveals some issues.
But on a positive point that is something you will now be well versed in if you build another model like this.
Hope your corrections go really well.
Tony
Sticky Wickett
#29 Posted : 26 June 2020 12:22:22
Keep at it Budgie! It might be frustrating but the results will be worth it in the end.
Phil W.
#30 Posted : 26 June 2020 14:43:05
You're doing a brilliant job Budgie despite the 'setbacks'!Cool I know what its like with things not lining up, when I was building my card Sopwith Pups I found that copies I scanned were not lining up exactly with the originals. I then discovered that the scanner for some obscure reason had a default copy setting of 97%! Once I realised that I had to set the thing manually to 100% on each separate scan it was fine.Blink( I've now upgraded to an Epson all in one scanner/printer and the copy function on that one is 100% as standard - much easier!)
I think with your decks, as long as the actual length of the deck fits with your bulkheads and keel I would ignore the frame slots and mark the decks to your own framework for the slots - seems like less work that way!Cool
Best of luck!
#31 Posted : 28 June 2020 00:04:10
Model building.... such a rewarding hobby but can be the most frustrating too when something doesn't work out the way it should.... Keep at it Budgie, it will all be worth it in the end.... What you've done to date is looking good....Cool Cool Cool
budgie
#32 Posted : 18 September 2021 10:42:17
BigGrin Will be keeping at it Alan
Not posted on this one for a wee while
Was getting embarrassed at my number of attempts to get it right to my satisfaction
I was not going to post until I had achieved the hull I wanted and pleased with
BUTFlapper
Watching a quiz show they wanted to know who quoted a phrase which seemed to fit ME and my attitude
The question being along the lines of who quoted
“Success is going from failure to failure without loss of enthusiasm”
I thought it summed me up perfectly with my number of attempts
Failing but enjoying the journey
Reminded me of my Dad when I used to volunteer my service (free of charge by the wayLOL LOL ) to help out in the garden or house
Kind of hoping that I would get my next airfix model from Woolies at the weekend
Realising that the task was not as easy that he made it seem and getting disheartened he would mention this bloke called Percy V Rance
Took me a few years for that to sink inLove
#33 Posted : 19 September 2021 12:50:37
Drool Drool Drool .. I think you have the right attitude, much like my own. There are many challenges, in life as well as modelling. Question is, do we just give up or do we soldier on and accept the challenges for what they are. You're like me, take it all in your stride and make the most of it. That way you will find the solutions you seek to overcome the challenges that have been set. You're doing a fab job, she's looking good and I look forward to seeing more of her as you progress.... Well done bud....Cool Cool Cool
Kev the Modeller
#34 Posted : 20 September 2021 20:19:15
Alan is right in what he says Stewart, better to rise to the challenge and harness that desire to succeed in order to conquer what is challenging you. It is easier to give in than it is to keep trying, but by eventually succeeding the feeling of satisfaction will be truly immense compared to the feeling of utter dejection if you just give up? Either way, when you look back on your modelling achievements in later years, you will remember this build for good or bad reasons, but if it was me, I'd rather look back and remember that I persevered and conquered and made myself a better modeller because of it?!
Keep going mate, nothing's impossible, you just need to find the solution that makes it possible! Smile ThumpUp
Kev
Per Ardua Ad Astra
2 Pages <12
This page was generated in 0.979 seconds.
