power supply Options
R2D2Nut
#1 Posted : 10 June 2020 17:23:38
Someone had already asked this and never got an answer. I got my charger mixed up Confused with some others and not sure which one it is. Does anyone in the US preferably since that is where I'm at, know how to be able to identify it or know the specs. I think it is a 15v.
Thanks in advance.
Fred
#2 Posted : 10 June 2020 22:45:18
Hi Fred
Although I’m in the UK, the one I have is an output of 15v - 2000mA. Hope that helps
R2D2Nut
#3 Posted : 13 June 2020 13:26:33
Thanks Mark. I knew it was probably one of my 15v, and the plug should be a negative center correct?
As it happens, I have an old color computer that uses a 15v, and one of these is a negative center and one has a positive center. But after I get this sorted, I am getting a Sharpie and some tags BigGrin
Thanks again Mark
Markwarren wrote:
Hi Fred
This page was generated in 0.092 seconds.
