3 Pages 123>
Tamiya 1/12 Porsche 934 Options
kpnuts
#1 Posted : 16 June 2020 21:25:09
Hi all this will be my next build looks up to Tamiya normal standards but when I first assembled the engine block the fit was awful and I had to use clamps scarily tight to pull the engine halves together (luckily this area is hidden by the timing chain cases) also luckily the gearbox is a perfect fit so maybe the engine halves were warped for some reason and that will be the only problem I get. Which is also lucky as I intend to build the engine on a display stand to be put alongside the car (as if it's just been rebuilt ready to be put back in)The body moulding is awesome hardly any seams at all and the detail in the kit seems incredible
This is the same scale as the Bentley so is quite a large car.
kpnuts
#2 Posted : 17 June 2020 21:05:23
Ok so here is a start on the engine.
#3 Posted : 17 June 2020 23:04:20
Not a million miles away from the Tamiya Porsche 935 I started a while back and then shelved for a while.
It will be really good to see how you get on with yours.
Keep posting Ken.Love
kpnuts
#4 Posted : 18 June 2020 20:36:21
More work on the 934 engine.
#5 Posted : 19 June 2020 08:03:37
Looking good Ken.Love
#6 Posted : 19 June 2020 08:14:34
Keep it coming Ken. Looking good so far.BigGrin
kpnuts
#7 Posted : 19 June 2020 20:42:10
Thanks guys.
Hi all more done to the engine (the rest seems to be going together in the usual tamiya fashion (in other words perfectly)
kpnuts
#8 Posted : 21 June 2020 15:52:11
Hi all more work on the engine and a start on the bodywork
kpnuts
#9 Posted : 21 June 2020 20:58:25
Hi all made a start on the engine stand and did some work on the front end.
Kev the Modeller
#10 Posted : 22 June 2020 21:31:02
Well ... I'm struggling to understand why anyone would think that a hairy tattooed leg would make a great backdrop for a model ... or am I missing something here? Confused Huh Glare
Kev
Per Ardua Ad Astra
#11 Posted : 22 June 2020 21:36:53
Kev
LOL LOL LOL Laugh Laugh Laugh
(Model does look good though...)
kpnuts
#12 Posted : 24 June 2020 21:19:35
It was just that it was the best angle to photograph it at.
Hi all more work on the engine.
kpnuts
#13 Posted : 26 June 2020 20:40:08
More work on the engine and a start on the body.
mpfiend
#14 Posted : 27 June 2020 08:16:26
Nice progress,
what paint did you use for the body?
K.
kpnuts
#15 Posted : 27 June 2020 13:19:08
Tamiya cobalt green ps54
mpfiend
#16 Posted : 28 June 2020 09:59:47
Thank you.
kpnuts
#17 Posted : 28 June 2020 20:18:59
Hi all well the tamiya supplied engine is done, I've looked on line but cant find picures the throttle linkages, I will have to ask my boss if he has any references (he seems to have an know anything Porsche related (hes an advisor on several official Porsche boards and is highly respected for his knowledge))started the decals, which are great but, the ones round the grill are really hard especially the ones around the square cut outs (if I could have guaranteed the colour match it would have been far and away easier to mask and spray it.
Ps I've barely started the decals (what ever happened to the English version (which I much preferred transfers) decals, where did that even come from you transfer the image from one place to another what you de (cant even think where cal fits in) sorry rant over, I just dont understand it.
CaptnBirdseye
#18 Posted : 29 June 2020 16:39:23
Rank: Superelite
Drool WOW Ken, that's looking good! Love the colours.
Gray
kpnuts
#19 Posted : 29 June 2020 20:19:28
Thanks gray
kpnuts
#20 Posted : 30 June 2020 21:11:53
Done some work on the fuel tank. a word of caution to anyone building this kit. When it comes to mounting the oil tank, on page one of the instructions it tells you to attach the mount for the oil tank, unless you skip ahead and build the oil tank first dont attach the mount in the first picture the bracket on the left had side is for the oil tank (the shelf with the oblong rail coming out from the side.
The steel pipe laying on its side next to it in the next pic goes into the tank and then into a hole in the bulkhead.
In the position of the next picture.
Here is a picture of the oil tank in position
Getting that pipe into the hole in the bulkhead and into the hole in the oil tank with that bracket in place is impossible (on this model of course that bracket was well and truly stuck) so I cut that rail off in order to get that pipe in then glued it back on again.
A better option would have been to attach the bracket and tank with the pipe on at the same time.
Here are some pics of the fuel tank.
3 Pages 123>
This page was generated in 0.207 seconds.
