R2D2 start up problems Options
Curtis12
#1 Posted : 18 June 2020 19:49:03
Rank: Newbie
Hi when turning on the R2d2 it jerks forward like it says it should the head does not turn around and the light does not go blue it stay red and that is all it does any body had same problem and no how to fix it
Cheers
Mick
#2 Posted : 19 June 2020 07:58:24
Hi Mick
It sounds like a power problem, maybe with the batteries. A troubleshooting guid to help can be found here.
Troubleshooting Guide
Pay particular attention to the battery contacts in the battery box. It also shows how to check if there is the right voltage.
Curtis12
#3 Posted : 20 June 2020 07:17:00
Rank: Newbie
Thanks mark I’ll try that I did everything with the batteries it said charged them all individually with the charger got the ones they asked for but I will try that and see if it works
Cheers
Mick
#4 Posted : 20 June 2020 08:05:00
Cheers
Mick
Hi Mick
Sometimes the contacts on the batteries don’t make contact in the battery box. Also thoroughly check the cables making sure there is a good contact and not inverted.
Good luck
This page was generated in 0.144 seconds.
