Handy and helpful? Options
Heinzy
#1 Posted : 05 September 2011 10:25:22
Hey guys, I had a stroke of genius the other day regarding the overall size of the finished model
I printed off a 1/8 scale plan of the car and pasted it into a storage container
This way when I finish a part, I can put it into place of where its gonna end up
I think it looks good too, seeing the car come together!
Just thought I'd share this, I've attached an image to make it clear what I'm talking about!
The Brawn Build
Wentworth Court Dolls House
The MP4/4 Build
#2 Posted : 05 September 2011 10:27:51
Good Tip HeinzyCool
kryten2b
#3 Posted : 05 September 2011 11:12:39
brilliant idea, i like it ThumpUp
Well spin my nipple-nuts & send me to Alaska
Current Builds:
McLaren MP4-23Finished
007's Aston Martin DB5Finished
Millennium Falcon
R2-D2
BTTF Delorean (Maybe)
Austin
#4 Posted : 05 September 2011 22:24:04
Dude do you have a local pub?
Heinzy
#5 Posted : 06 September 2011 10:55:27
lol no I'm a surveyor!LOL
What made you ask that?
The Brawn Build
The MP4/4 Build
Austin
#6 Posted : 06 September 2011 11:12:46
Just thought you might have a bit to much spare time to come up with ideas like that heinzy, lol. Laugh
only1ianuk
#7 Posted : 06 September 2011 19:14:02
I've been doing much the same but taking pictures after each delivery. Then i got a display case to put it all in rather than fiddling about with ordering it each time!
The below pictures are what i currently have!
Part 1.jpg (1,322kb) downloaded 83 time(s).
Part 2.jpg (1,543kb) downloaded 65 time(s).
Part 3-4.jpg (1,627kb) downloaded 63 time(s).
Part 5-8.jpg (1,464kb) downloaded 64 time(s).
Part 9-12.jpg (1,588kb) downloaded 62 time(s).
Part 13-16.jpg (1,417kb) downloaded 73 time(s).
Part 17-20.jpg (1,532kb) downloaded 124 time(s).
Warthog
#8 Posted : 06 September 2011 22:31:19
Are you doing the SWB version? Think you might stuggle with the Display case, as nice as it is... Crying
only1ianuk
#9 Posted : 06 September 2011 23:17:52
SWB? Sorry im fairly new to models. I think i'm alright with the sizings as Deag gave us the length then worked out the width from what we've got and worked out the height is about double the wheels. It should fit nicely with any luck! BigGrin
Heinzy
#10 Posted : 07 September 2011 08:56:08
Just have an active mind!
That display case looks the part, did you make it yourself or was it made to order?
The Brawn Build
The MP4/4 Build
only1ianuk
#11 Posted : 07 September 2011 10:27:56
Made to order. Least if it is wrong i've got a few 1/18's which will happily fill it!
IAN
#12 Posted : 07 September 2011 11:56:22
Hi Ian...
>>>Made to order. Least if it is wrong i've got a few 1/18's which will happily fill it!<<<
I would love to know what company you got the display case from as it looks great and would like to build a car next and diplay in a case as good as that one you have ?
best regards,
Ian
Ian
Wish list: Bentley Blower
Warthog
#13 Posted : 07 September 2011 14:08:34
Short Wheel Base :-) Just looks small but if you have gone by the dimensions given then I'm sure it wil fit fine BigGrin
Austin
#14 Posted : 07 September 2011 14:32:44
I thought the same warthog, it does look a bit short but hopefully it will be fine for Ian. Fingers crossed Ian.
only1ianuk
#15 Posted : 07 September 2011 20:44:31
The inside dimensions are L640mm x W300mm x 200mm. I gave a bit extra in terms of size just to make sure, Plus i've got a 1?43 scale to go inside with it!
I got the case from http://www.modeldisplaycases.co.uk.
The guy is really good as well!
Warthog
#16 Posted : 08 September 2011 17:05:57
You should be fine then as the Model is supposed to be 594 mm long and I would say 200mm wide... I have a few cases I made with a couple of 1/12th in so I'll wee if they are good enough and make a few more..
