10 Pages 123>»
1/16 Hobby boss Tiger 1 Options
#1 Posted : 30 June 2020 16:59:33
HI all sorry for my absence from the forum ,but its strange times plus took my laptop to get fixed before lock down and had too wait till now to get it backCrying Any how alot hasn`t happened with my modelling and with not having the modellers mojo until my daughter bought me this for my birthdayBigGrin and so i thought that i would super detail this Cool Abber etch, gun barrels.voyager etch Atak zimmerit ,taigen metal hatches,figures,etc i will go through each add on as i go on with the build Cool
#2 Posted : 30 June 2020 17:04:37
First a bit about this kit i think its the henglong r/c kit (mid production tiger1) and so the hatches and some other bits are moulded on so a bit of surgery here its well packed and when built from the box would build up wellCool my build started about a month ago so i have a lot done so will post what i`ve done so far and there is a lot of etch Cool cheers philCool
CaptnBirdseye
#3 Posted : 30 June 2020 17:45:23
Rank: Superelite
BigGrin Phil! Good to see you back ThumpUp
Nice choice of kit, this one. You’re right it looks to be ex R/C with all the gubbins removed. Enjoyed building mine, but couldn’t tell you where it is Confused
Can’t wait to see what you do with it, but I assume you’ll be adding zimmerit?
Regards Gray
#4 Posted : 01 July 2020 09:22:55
Hi Phil, great to see you back with us, you've been missed.....Cool Cool
Looks like this is a build that is right up your street and I look forward to following your progress as usual... Good luck with the build.....Cool Cool
#5 Posted : 01 July 2020 10:56:26
Regards Gray
Gray can say you will be surprised what i`m doing with itBigGrin and thanks for the welcome back mate cheer`s philCool
#6 Posted : 01 July 2020 10:57:52
Thanks Alan hope your well mate BigGrin well i hope every one likes it LOL cheer`s PhilCool
#7 Posted : 01 July 2020 10:59:08
The kit comes well packed and the parts in separate box`sCool
#8 Posted : 01 July 2020 11:01:29
First up i did the tracks which are individual links held together by metal pinsCool
#9 Posted : 01 July 2020 11:03:58
then moving on to the lower hull first i blanked off the R/C holes and filled the battery box edgesCool
#10 Posted : 01 July 2020 11:08:51
then added the track tensioner guide covers which were missing out of stripCool
#11 Posted : 01 July 2020 11:11:11
then moving to the front added weld beads to the drive sprocket housing and where the front plate attachesCool
#12 Posted : 01 July 2020 11:18:14
then added the armoured covers for the transmission which where missing from the kit ,these are white metal from Taigen which i got from a company in the uk are priced very reasonable and they stock everything for this scale of tank they are called ForgeBear tanks https://www.forgebeartan.../Featured_Products.html
i then added weld beads around theseCool
#13 Posted : 01 July 2020 14:11:30
here are the armoured transmission plates before i installed themCool
#14 Posted : 01 July 2020 14:13:44
Next up was the swing arms ,which are anchored inside with springs and screws
#15 Posted : 01 July 2020 14:18:01
and the idler swing arms screw in aswellCool
#16 Posted : 01 July 2020 14:19:13
Drive sprockets idler wheels all screw togetherCool
#17 Posted : 01 July 2020 14:22:54
As do all the sets of wheels here shown built up the tyres are separate and are rubber which need to be sanded to rough them up and will be added once the wheels have been paintedCool
#18 Posted : 01 July 2020 14:25:05
The lower hull was then primed in Halfords plastic red primerCool
#19 Posted : 01 July 2020 14:30:28
I then moved on to the upper hull and here`s where the fun really began, i wanted to add figures to the tank and the hatches for the driver and radio operator are moulded on as is the jacking block and side fenders along with the front fenders, all these were removed as i wanted to add more detail and Abber and voyager do replacement brass sets along with the Taigen white metal hatches Cool
#20 Posted : 01 July 2020 14:42:56
They are all filled and smoothed along with various holes for the tools and cables which will be replaced with the brassCool i turned my attention to the front plate where the drivers block and ball machine gun sits ,the drivers block is moulded shut which looked odd so i cut this out and separated the two halves and added a piece of perspex to it , i think it looks a lot better the gaps were filled with plastic card were the material was removed from the sawingCool
Guest (8)
10 Pages 123>»
This page was generated in 0.478 seconds.
