4 Pages «<234
Alemo's build Options
alemo
#61 Posted : 30 June 2020 12:01:04
Issue 19
The main problem I have had is small tubes to fit over pins that are too large. The tube collapses instead of sliding over the pin. I finished up making a small slit in the end of the tube and then using superglue to hold it.
Alec
alemo attached the following image(s):
Adapt, improvise, overcome.
Bandit750
#62 Posted : 30 June 2020 14:33:10
Your build is looking fantastic ThumpUp , just wondering if the steering damper is metal or plastic.
If deliveries go to plan you should have it finished by the end of the year. Something positive to come out of 2020 after all Mellow .
#63 Posted : 30 June 2020 17:03:07
It's looking really BIG. That's going to be a very impressive model when it's finished...Drool
alemo
#64 Posted : 30 June 2020 18:25:35
Bandit 750 and Roy,
Thanks for looking in and comments, the steering damper cylinder and shaft are metal, regulator and regulator rod are plastic.
Unless something goes adrift completion should be November (fingers crossed)
Alec
#65 Posted : 01 July 2020 09:25:16
She looks stunning Alec, one to be proud of when done....Drool Drool Drool
alemo
#66 Posted : 01 July 2020 11:46:54
Thanks Alan nice to have your interest, it means a lot.
Alec
CaptnBirdseye
#67 Posted : 02 July 2020 08:53:28
Rank: Superelite
BigGrin Really coming together Alec ThumpUp
smk80
#68 Posted : 21 July 2020 01:17:49
Rank: Newbie
Hi Alec,
Builds looking great. We appear to be at a very similar stage however I have no idea where the ends of 2 tubes connected to the tube connectors on the right handlebar need to to be connected. Every image I see appears to have them just tucked under the handlebars not actually connected to anything. I have looked everywhere and can’t find anything that tells me. Do you happen to know where they go?
Thanks
Stuart
alemo
#69 Posted : 21 July 2020 10:01:18
Hi Stuart,
Not a clue!
I, like you have searched everywhere and can find nothing. They appear to cross to the left side and then disappear, what we need is a real biker to advise us. I suspect that the tubes or are they wires connect to somewhere that is no longer accessible on the model.
What they do on a real bike I have no idea.
Alec
Bandit750
#70 Posted : 21 July 2020 12:07:40
Hi
With reference to the cables they are the throttle, accelerate and return cables. On many motorcycles there is a cutout in the frame on the left hand side where they pass through and attach to the throttle bodies.
In the case of this model I will just be placing them underneath the airbox when I get that far. But if I can I will have a look to see if they are long enough to actually get them to reach the throttle bodies. Means removing the airbox though.
Hope this helps a bit
alemo
#71 Posted : 21 July 2020 18:44:08
Thanks Bandit750,
At least we are sure of what they do, but should not forget that it is a model.
Alec
smk80
#72 Posted : 21 July 2020 20:45:37
Rank: Newbie
Thanks all for such prompt replies. I was however worried that this would the case. Without somewhere to put them my OCD is gonna go into overdrive.
The cables definitely aren’t long enough to reach the throttle bodies, certainly not from the left side anyway. I may just have to place them under the air box too.
Seems strange however that they would go to such lengths to create such an accurate representation and then neglect this component when the solution seems so simple?
migman
#73 Posted : 01 October 2022 12:00:49
Rank: Beginner Level 1
It has been great to be ale to follow your build and the photos are a big help too The old saying a picture saves a thousand words comes to mind , Will be great to see the rest of your build you are doing a great job sir for sure, I have just got my first box a few weeks ago and cannot wait for the next one this is going a frustrating time all the waiting LOL But really looking forward to getting going
Regards Tony
Our Dog used to chase the Bloke next door on his bike , It got that bad we had to take his bike off him
4 Pages «<234
