52 Pages «<34567>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#81 Posted : 07 August 2020 16:43:10
Junction box fitted.
Sticky Wickett
#82 Posted : 07 August 2020 16:44:15
I then made another electrical box. The attached photo shows it painted and fitted. It's indicated by the blue arrow.
Sticky Wickett
#83 Posted : 07 August 2020 16:45:48
A drilled support plate was then made and fitted. The attached photo shows it fitted, painted and indicated by the blue arrow.
Sticky Wickett
#84 Posted : 07 August 2020 16:51:06
The next part was a little more involved to make; the emergency rudder control. This was used in the event of rudder motor failure where the hydraulics had collapsed. The manual emergency rudder control was then engaged and navigation could resume.
The attached photo shows it completed and ready for painting.
Sticky Wickett
#85 Posted : 07 August 2020 16:53:14
Painted.
Sticky Wickett
#86 Posted : 07 August 2020 16:54:58
Emergency rudder control fitted. The blue arrow indicates where i connected it to the rudder motor via 0.8mm diameter brass rod to represent the connecting shaft.
Sticky Wickett
#87 Posted : 07 August 2020 16:56:00
From another angle.
Sticky Wickett
#88 Posted : 07 August 2020 16:56:50
Side view.
Sticky Wickett
#89 Posted : 07 August 2020 16:59:53
Front view showing the large hand wheel which was turned manually by the operator to change the angle of the rudder.
Sticky Wickett
#90 Posted : 07 August 2020 17:02:38
That concludes this update. I should be back to my weekly posts from next week, so stay tuned for another instalment.
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
Phil W.
#91 Posted : 08 August 2020 07:35:38
That is filling out with lots of nice details now Phil.
Tony
goddo
#92 Posted : 09 August 2020 08:29:42
Phil, this is an amazing build with such fine detail.
Congratulations and keep the updates coming.
Chris
#93 Posted : 09 August 2020 09:22:15
Excellent work Phil, looks like the real thing.Love
Sticky Wickett
#94 Posted : 21 August 2020 16:10:39
Tony
Thank you Tony!BigGrin
Phil W.
Sticky Wickett
#95 Posted : 21 August 2020 16:11:32
Chris
Thank you very much Chris!BigGrin
Phil W.
Sticky Wickett
#96 Posted : 21 August 2020 16:12:39
Thank you Mark! Diving now, diving now! Well, not quite!Flapper
Phil W.
Sticky Wickett
#97 Posted : 21 August 2020 16:14:39
Good afternoon from 'The Dockyard'.
More progress has been made on fitting out the aft torpedo compartment.
First up, a small valve.
Sticky Wickett
#98 Posted : 21 August 2020 16:15:41
Small valve painted, pin washed and fitted. See arrow.
Sticky Wickett
#99 Posted : 21 August 2020 16:17:35
Rudder indicator, painted and ready for fitting. The dial face i cropped from an actual photo, resized it in power-point, printed and cut to shape.
Sticky Wickett
#100 Posted : 21 August 2020 16:18:41
Rudder indicator fitted.
Guest (36)
52 Pages «<34567>»
This page was generated in 0.705 seconds.
