36 Pages «<56789>»
MWG build diary of Nelson's HMS Victory Options
#121 Posted : 09 September 2011 00:33:50
ISSUE 40
These are the Gallery side panels out of the beakers, now totally dry:-
#122 Posted : 09 September 2011 00:36:38
Now I turn the Hull over and attach the first strips to the Gallery supports like this:-
#123 Posted : 09 September 2011 00:40:07
First Part of ISSUE 41
I glued the curved edge of frame 79 below the upper row of windows:-
Do you like the pegs?
#124 Posted : 09 September 2011 11:39:14
Love the pegs, who needs clamps. Home made?? Watching your progress with great interest.
#125 Posted : 09 September 2011 18:49:43
Hi Hans,they are taken from my wife`s peg basketLaugh Laugh
#126 Posted : 10 September 2011 14:05:01
ISSUE 40
Well I finished of this issue with the fianl build up of the gallery support :-
#127 Posted : 10 September 2011 14:08:02
ISSUE 41
I shaped the dowl to fit in the slot for the Bowsprit:-
#128 Posted : 10 September 2011 14:10:27
Then I shaped the Bowsprit in the fore deck, and fitted the fore deck:-
#129 Posted : 10 September 2011 14:13:04
And to end this session I removed the pegs from the gallery rear support thanks for watching
kas
#130 Posted : 13 September 2011 00:08:50
Rank: Amateur Level 1
Coming along nicely, been following this build for a while now. I've just got back to making progress on my build but a long way behind as still at the planking stage.
Karl
#131 Posted : 13 September 2011 00:16:00
Hi Kas it does not matter where you are in the build as long as you are enjoying itCool BigGrin
and thank you for your nice commentsBlushing
#132 Posted : 16 September 2011 22:19:46
I will be copper tiling in approx 2 weeks time, using this EVO STICK serious glue.
It is solvent free, and gives approx 3 minuets to put the part in place (more than enough time) :-
#133 Posted : 19 September 2011 18:37:56
Hi everyone I will be on holiday from tomorrow 20th Sept untill 28th Sept, will speak on my returnBigGrin Cool
#134 Posted : 19 September 2011 20:11:29
EnjoyThumpUp
#135 Posted : 19 September 2011 22:53:17
Cheers MR TBigGrin Cool
tom.ganc
#136 Posted : 23 September 2011 15:20:27
Good luck mate ;)
#137 Posted : 23 September 2011 18:55:12
Looking good mike
Cool
#138 Posted : 24 September 2011 13:54:15
great build interested to see how the copper plating goes Cool
#139 Posted : 28 September 2011 17:09:17
Hi Jase, thanks for that.
I will be starting the copper very soonBigGrin Cool
#140 Posted : 05 October 2011 09:49:02
Hi everyone did some more work on the old girl, this time the Gallery Port side.
I cutout more of the wood which will be infront of the windows in case I use clear acetate to cover the windows to show things inside like flooring etc :-
Guest (6)
36 Pages «<56789>»
This page was generated in 0.749 seconds.
