10 Pages «<678910>
1/16 Hobby boss Tiger 1 Options
#141 Posted : 16 August 2020 16:50:37
The top of the hull, rear and turret primed redCool
#142 Posted : 16 August 2020 16:52:12
Along with the side fendersCool
#143 Posted : 16 August 2020 16:53:28
The white metal tools where cleaned up and i started to paint theseCool
#144 Posted : 19 August 2020 14:50:30
After priming i used the ammo of mig chipping fluid then applied a coat of DunkelglebCool
#145 Posted : 19 August 2020 14:52:13
Primed the rear and more chipping fluid along with patches off grey and added the exhaust flapper`s and the gun travel lock which i constructed earlier from the abber etchCool
#146 Posted : 19 August 2020 14:55:46
primed the front with the red primer and the grey and added the chipping fluid hereCool
#147 Posted : 19 August 2020 14:57:37
Then the Voyager track guide rope was started here you have to cut to the required length and drill the resin ends out to except the ropeCool
#148 Posted : 27 August 2020 12:24:41
The spare track links are missing the handles on the brackets so so wire was added along with rod for the track pinsCool
#149 Posted : 27 August 2020 12:28:58
The tank has now had one coat of dunkelglebCool
#150 Posted : 27 August 2020 12:31:13
The barrel cleaning rods and jacking block tried on for fitCool
#151 Posted : 27 August 2020 12:32:27
The tracks fittedCool
CaptnBirdseye
#152 Posted : 27 August 2020 12:34:11
Rank: Superelite
Drool Love Now that's looking the business Phil ThumpUp
#153 Posted : 27 August 2020 12:34:21
Started to paint the figuresCool
#154 Posted : 27 August 2020 12:36:18
clamps and clasps added to the front for the towing c clamps and the towing hooks addedCool
#155 Posted : 27 August 2020 12:37:44
How it looks nowCool added the track guide rope hereCool
#156 Posted : 27 August 2020 12:40:36
Thanks Gray for looking inBigGrin
Regards PhilCool
#157 Posted : 31 August 2020 12:25:02
Next i added the front track guardsCool
#158 Posted : 31 August 2020 12:26:35
Then the Rear onesCool
#159 Posted : 31 August 2020 12:28:32
Then the side skirts added also used the Masterclub bolts hereDroolCool
#160 Posted : 31 August 2020 12:29:46
Added the casting numbers to the mantlet
Guest (8)
10 Pages «<678910>
This page was generated in 0.415 seconds.
