52 Pages «<45678>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#101 Posted : 21 August 2020 16:23:02
The next 'mini-project' was to fabricate the two block and tackle assemblies. These were used to lower the torpedo into the compartment, once it had been manouvered through the loading hatch.
The fist step was to make two wheels that keep the chain located correctly within each block and tackle assembly.
Sticky Wickett
#102 Posted : 21 August 2020 16:24:33
The attached photo shows both block and tackle assemblies near completion along with the aforementioned guide wheels and also two rollers.
Sticky Wickett
#103 Posted : 21 August 2020 16:25:51
Block and tackle assemblies filed to shape, painted, pin washed, rollers fitted and ready for the guide wheels and chain.
Sticky Wickett
#104 Posted : 21 August 2020 16:28:04
This photo shows the rollers fitted. Rollers and guide wheels had 0.6mm diameter hole through the centre of each and corresponding holes in the block and tackle assemblies to align a brass shaft.
Sticky Wickett
#105 Posted : 21 August 2020 16:29:16
Another angle showing the block and tackle assemblies.
Sticky Wickett
#106 Posted : 21 August 2020 16:29:55
Guide wheels painted.
Sticky Wickett
#107 Posted : 21 August 2020 16:30:56
Guide wheels and chain fitted.
Sticky Wickett
#108 Posted : 21 August 2020 16:32:38
I bought the chain from Scale Link. See photo for product details.
Sticky Wickett
#109 Posted : 21 August 2020 16:34:35
Block and tackle assemblies fitted. The two loose ends of chain were tied to the main chain via fine wire.
Sticky Wickett
#110 Posted : 21 August 2020 16:36:53
That concludes this post.
Thanks for looking in and your comments, have a nice weekend and happy modelling!BigGrin
Phil W.
#111 Posted : 21 August 2020 17:19:39
Crying Crying Crying I`m gonna have to build my Hachette U96 under cover.
Its gonna look mighty empty. Blink
Just jesting, LOL as this is a fantastic show of kit upgrading and deserves every chance of being shown on the web.
Keep up this excellent build. Love Love Love Love Love
#112 Posted : 21 August 2020 19:47:10
Just amazing on the level of detail you are going to.Love Love
BTW never have anyone on board called Dave. When they all shout his name just hope all the hatches are closed.Flapper LOL
CaptnBirdseye
#113 Posted : 23 August 2020 11:56:12
Rank: Superelite
Laugh You and me both Del LOL LOL LOL
Seriously though, this build is an education as well as a pleasurable read ThumpUp
Regards Gray
Garth
#114 Posted : 25 August 2020 12:41:16
Hi Phil,
Another fantastic updateDrool Drool Drool
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Sticky Wickett
#115 Posted : 04 September 2020 09:33:55
Good morning from 'The Dockyard'.
Thanks for all the comments guys, much appreciated!
I've now turned my attention to building the two main motors. These would take their power from the batteries to turn the prop shafts and propellers.
The first part was to spend a bit of time just looking at photos and mentally breaking down these motors into basic shapes to form the body.
Essentially they are cylindrical, consisting of various diameters and widths, so this is what i started to make.
I used 6.5mm square acetal strip, cut to lengths that match the different widths of the individual cylinder sections. Drilling a 2.0mm diameter through the centre of each gave me a datum.
I then used a compass cutter to form various diameters from 0.5mm thick acetal sheet and finished off by opening out the centre hole to 2.0mm.
Sticky Wickett
#116 Posted : 04 September 2020 09:36:22
Using a 2.0mm diameter brass rod i could slide two circular sections over the brass rod with the square section sandwiched in the middle, all glued together.
Sticky Wickett
#117 Posted : 04 September 2020 09:38:18
The next step to complete one of these cylinders was to fix a strip of 0.25mm thick acetal sheet, cut to length and width and glued to the outside edge.
Sticky Wickett
#118 Posted : 04 September 2020 09:39:55
I had several of these cylinders to make in the same fashion as described before.Blink
Sticky Wickett
#119 Posted : 04 September 2020 09:43:11
These individual cylindrical sections were then fixed together using the brass rod as a locator so that i ended up with the basic shape of the two main motors.
Sticky Wickett
#120 Posted : 04 September 2020 09:45:24
Now i can start to add detail beginning with edging using 1.0mm x 0.5mm acetal strip.
Guest (14)
52 Pages «<45678>»
This page was generated in 0.447 seconds.
