This is the Italeri 1/48 kit    Had some damage in the box, I emailed the company but they would replace fro free and wanted €20 to replace them My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits. Dry dock no room to display:-. Bismarck, U96. To build:-. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
 I did manage to repair these My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Cockpit is plain and simple.     My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So I've added sidewalls and a front centre section.    My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Next was to add detail to the cockpit, for this I used Eduards F14A cockpit designed for the Tamiya version. Before.   After.    My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Engine exhaust units, again the kit parts very simple  So I'm using the Aries units again not designed for this kit.  Right unit Aries. Left unit kit.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
To get the aries units to fit I had to place them loose inside the kit while I glued it all together, Then I was able to adjust the kit to allow them to fit.   My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Joined: 21/01/2016 Posts: 38 Points: 114 Location: Queanbeyan, NSW, AU
I've got this kit as well. Following your work now. Thanks for posting
 Those Ares exhaust units make a great difference, and so do the cockpit parts
You are going a grand job so far, love the detailing in the cockpit. Mark Regards Markwarren (Mark) Admin
Thanks guys. Junk Pilot all I would say about this kit is research the model if your doing the VF-1 Wolfpack the kit is very basic and is also missing some details My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So heres where it is.. Just to show the repair on the intakes.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
I upgraded the seats.    My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Paint scheme done on the fuselage.      My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
All parts painted and sealed.    So all I need to do know is add the decals and fit it all together. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Looking real nice. 😀👍 On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looking excellent. Mark Regards Markwarren (Mark) Admin
Hi guys thank for looking in heres the next update. Decals all done only took two days... So this is how the instruction show the fuel pods. I looked everywhere and could fine any reference showing them like this.  So I've adapted them to what I could fine.  As per the instructions.  Again with these the decals didn't look right so I added some more from the stash.  And these also didn't look right so I relaid them and add some more.  My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
So decals added, will seal them and then look at adding some dirt.   I've switched a couple of the decals the walk way on the top of the fuselage these are shown as going inside the intakes which do not have any marking like these, and the ones that where meant to go there looked to small. I've also added the black strips to show the slits by the gun mounting, these where some black lines I had on a decal sheet in my spare stash plus the area in front of the gun nozzle. My Favourite Building:- 1919 https://forum.model-spac...=339517&#post339517 -
Hi Mustang, That`s all looking very sharp and coming toward a nice conclusion. Well Done. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
