2 Pages 12>
Class 08 Options
Mustang
#1 Posted : 08 September 2020 09:51:48
So the stage coach is finished just waiting for a display case to arrive, so I’ve been looking at what I could build next plastic, wood or metal Confused Confused
So I’ve decided to look at building a Class 08 Shunter, this will be the kit by JLTRT “Just Like The Real Thing” the company has now closed.
So at the moment I’m just doing a little research into possible versions numbers D3045, D3668, 08534 or 09018 and also going though the instructions looking at where all the bits go. Blink
Photos later to show what’s you get in the kit. If anyone has any photos or info on any of these please show as the more info the better BigGrin
To build:-
Mustang
#2 Posted : 11 September 2020 08:24:29
So heres what comes in the kit.
Lots of packets which contain Resin, White metal and Lost wax parts.
To build:-
Mustang
#3 Posted : 11 September 2020 08:26:48
Closer look at the Lost wax parts.
The White metal parts.
The Resin parts I'll show as I build the unit.
To build:-
Mustang
#4 Posted : 11 September 2020 08:29:38
These you have to buy extra, they don't come in the kit.
Slaters wheels.
Railtec Decals, in this case the wasp version.
To build:-
Mustang
#5 Posted : 11 September 2020 08:30:38
Ok so heres the Resin bits.
To build:-
Mustang
#6 Posted : 11 September 2020 08:35:30
Dry run to show what it looks like.
I'll be building the D3668 this loco is currently located at the https://swindon-cricklade-railway.org and a list of what they have there https://swindon-cricklad...ay.org/about/stock-list/
To build:-
Mustang
#7 Posted : 11 September 2020 08:44:40
So these are the bits needed for the Cab interior.
Sanded the horrible sinkhole marking from the interior of the roof.
There is a big area I don't like and thats the floor area, as you can see there are two screw holes these are used to secure the lower framework to the main unit. This needs to be removable in case the unit needs repairing.
Mine won't be a working unit i.e. no motor as I don't have the room of O Gauge layout, but I will install a gear box just incase I ever sell the unit and the next person wants to run it.
So I'll be adding a wooden floor section that can be removed, I also want one of the doors open so you can see inside better.
The cab has a lot of detail, but I'll possible add some more later after I've found photos of the real unit.
To build:-
Mustang
#8 Posted : 12 September 2020 22:53:57
Floor made from scrap pieces.
To build:-
Mustang
#9 Posted : 12 September 2020 22:56:57
Gearbox arrived today.
Dry run to see if/how it would fit.
To build:-
#10 Posted : 13 September 2020 09:57:11
This looks an interesting built. Looking forward to seeing this come together.Cool
Mustang
#11 Posted : 20 September 2020 21:16:35
This is the part for ihefront grill.
Simple to make just fold the 3 corners and solder the 4th, then insert the grills and solder tops and bottoms.
Dry fit.
Hand rails made from rod.
To build:-
Mustang
#12 Posted : 20 September 2020 21:18:58
Next was the main section, made up from 4 pieces plus the cab section.
Screws to hold the top section to the chassis
To build:-
Mustang
#13 Posted : 20 September 2020 21:22:32
Tool boxes and other compartments, theres different version so depending on which version your building.
I've not glued all of them on at the moment, reason was so I could make sure paint get down all the sides.
To build:-
Mustang
#14 Posted : 20 September 2020 21:25:03
Fitting the hardware.
The latches and small pieces are all fixed, the ladders are removable for painting.
To build:-
Mustang
#15 Posted : 20 September 2020 21:32:25
Next was to start work on the chassis section, the supplied screws and nuts where to big.
So I had to rummage around my spares, these are used to secure the side running plates.
Pickups and motor all installed and tested. The motor will be removed once finished so I can use it to test the next model.
Repositioned the motor.
Tested and all working fine.
To build:-
#16 Posted : 20 September 2020 21:39:07
All progressing very nicely.
Cool Cool Cool
Well done to date.
#17 Posted : 21 September 2020 08:21:56
It's looking great.
What scale/gauge is it?
Mustang
#18 Posted : 22 September 2020 17:19:20
Hi Roy,
Scale as we’re in the Uk is 1/48, O Gauge, 7mm
or for the European members scale is 1:45 or 1:43.5
To build:-
Mustang
#19 Posted : 15 February 2021 23:18:30
So I've added the detail to the lower side sections.
To build:-
Kev the Modeller
#20 Posted : 06 March 2021 21:12:33
That's looking excellent Ian, nice and tidy and well assembled. I think I prefer this model in the bare metal finish as opposed to the fully painted version. Makes it look like a proper 'model engineering' project don't you think!?
Very cool, well done on your build so far. Cool ThumpUp
Kev.
Per Ardua Ad Astra
2 Pages 12>
This page was generated in 0.264 seconds.
