1824 Stage Coach question Options
6649mgk
#1 Posted : 16 September 2020 16:45:49
Rank: Amateur Level 1
Hi, Can anybody tell me, in respect to the 1824 Stage Coach build, whether the inside is stained/waxed following completion of the lining? The instructions (?) do not say anything about this.
Thanks,
Mustang
#2 Posted : 16 September 2020 21:17:13
Hi Mark.
When I built mine I didn't add any Wax I just used a tin of ronseal which I've used on all my wood builds as it brings out the wood really nice, well I think so.
https://forum.model-spac...spx?g=posts&t=33710
I didn't seal mine until I had finished all the inside and the outside and I was ready to add the roof. I believe the instructions do tell you to seal the wood once the interior is done but personally don't.
Something my dad said never seal, stain or wax wood until you've glued all the piece together and your 100% sure nothing else needs glueing as glue will not give a strong reliable bond against these.
I hope this helps.
To build:-
6649mgk
#3 Posted : 17 September 2020 09:06:24
Thanks for you reply.
m
This page was generated in 0.098 seconds.
