52 Pages «<678910>»
1/48 scale U-Boat U230 [Part 3] Options
Sticky Wickett
#141 Posted : 18 September 2020 07:11:54
Good morning from 'The Dockyard'.
Thankyou for all the nice comments!BigGrin
So this week has seen me add more detail to the main motors.
The attached photo shows the manual cranking handles fitted. I'm not entirely sure, but i believe these were turned with a spanner while the inspection covers were opened, for maintenance.
They were made from 1.0mm OD, 0.8mm ID brass tube with a small length of 0.8mm diameter brass rod inserted into each section.
Sticky Wickett
#142 Posted : 18 September 2020 07:14:14
Looking from another angle.
Sticky Wickett
#143 Posted : 18 September 2020 07:22:11
The next stage was to start building some of the ancillary detail. The attached photo shows a starter, made from styrene rod and sheet.
Sticky Wickett
#144 Posted : 18 September 2020 07:23:11
I haven't fitted it yet, but this photo shows where it will locate on the port main motor.
Sticky Wickett
#145 Posted : 18 September 2020 07:26:00
I then turned my attention to a similar type of 'starter' for the starboard side. The black section is in fact part of an old biro!LOL It just so happened to have the right diameter!Flapper
Sticky Wickett
#146 Posted : 18 September 2020 07:35:13
This photo shows some of the detail on this starter including wire type latches.
Sticky Wickett
#147 Posted : 18 September 2020 07:36:42
The attached photo shows it in position, but not fitted, on the starboard main motor.
Sticky Wickett
#148 Posted : 18 September 2020 07:38:09
Sticky Wickett
#149 Posted : 18 September 2020 07:39:48
That concludes this update.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
goddo
#150 Posted : 18 September 2020 08:05:33
Great work Phil.
Keep the updates coming.
Chris
Garth
#151 Posted : 22 September 2020 11:51:25
Hi Phil,
Great update as always.Drool
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#152 Posted : 24 September 2020 08:18:47
Very nice work Phil.Love Love You must know your way around the engine of the real thing by now.Cool
Sticky Wickett
#153 Posted : 25 September 2020 08:29:09
Thank you Mark! Yes, i'm thinking of writing a Haynes manual on u-boat air compressors!LOL Flapper Now that would be a very specialised subject on Mastermind! lol.
Phil W.
Sticky Wickett
#154 Posted : 25 September 2020 08:31:07
More progress this week on the main motors.
The attached photo shows the 'starter?' connected to the starboard main motor.
Sticky Wickett
#155 Posted : 25 September 2020 08:32:19
'Starter?' fitted to the port main motor.
Sticky Wickett
#156 Posted : 25 September 2020 08:34:20
Now it's onto the final job of making the air coolers for both main motors.
The attached photo shows the scratch built electric motors that power the air cooler fans.
Sticky Wickett
#157 Posted : 25 September 2020 08:34:52
This photo shows the fan housings being made.
Sticky Wickett
#158 Posted : 25 September 2020 08:35:25
Air cooler casing being assembled.
Sticky Wickett
#159 Posted : 25 September 2020 08:36:16
Air cooler casing work in progress.
Sticky Wickett
#160 Posted : 25 September 2020 08:39:15
I then fitted mesh across the air cooler fan opening and finished off by wrapping a strip of 0.25mm thick styrene sheet to make the outer body.
The attached photo shows the air cooler fan housings and electric motors completed.
Guest (10)
52 Pages «<678910>»
This page was generated in 0.390 seconds.
