 Rank: Vice-Master  Groups: Registered
Joined: 20/04/2010 Posts: 545 Points: 1,536 Location: lossiemouth
to me screwing it down to a board through the keel is more holes to plug to stop water getting in if sailing , fixing to board buy other ways screwed clamps out side of keel etc is the way i am going
Willie,We build the Hull under this false keel this part does not go near the water,when we have built all thr ribs we unscrew it off the board, and plank a hull underneath MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
i know but water will find a way i have built a double plank boat be fore planks over lapping the first plank joints with the second plank and water still found its way in all because a pinhole in the middle of a plank ended up in the middle of a joint found out by flooding the boat in side and looking for the weep and if this build is the same as the bismarck you plank from the top down take a look at the builds on you tube the russin one good and how he fixes his planks with rubber bands so they pull in and up tight to the next one
Zeptrader wrote:I have seen this also but think it just shows a few sample steps and not a build diary. More of a getting started page to show any newcomers what to expect, if they do a build diary or any updates past issue 4 I would be very surprised and offer a MASSIVE appologey .
dont get too excited by it:)
oh and MWG, looking good but as Mr T pointed out watch the clamps, get it screwed to a board mate, superb stuff, I'll be doing mine after the race on sunday and updating a blog;) again!!! Have to agree with you Colin, its unlikely the build will be shown beyond issue 4
Its a double planked build, if you properly water seal inside and out with a proprietory water sealing method, then all will be fine .
Joined: 11/05/2011 Posts: 766 Points: 2,128 Location: Dagenham
Thanks for ya help so far lads I'm sure it won't be long before I'm bugging ya all again lol CURRENT BUILDS
Mclaren MP4-23 Ford 1/12 Shelby Mustang GT500 2010 HMS Pandora
ISSUE 2 Just thought you would like to see the Hood in its Dry Dock:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
You will see the tops of the ribs come off cleanly as they should:- MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
And finally for this session WOW SHE IS GOING TO BE BIG!!!!!! MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
nice one
 Hi following ure diary with interest i screwed my Yamato down to a PINE base, but unfortunately i kept it in the shed thinking its going to go in or under the water (as top heavy)therefore keeping it in the shed should not be a problem Over the winter period not realising that the birds had pinched half the roof so when it rained well u can guess where the leak would dribble onto The wood got sodden and even the base ended up warped therefore the false hull was warped too  Thinking about getting a tin can like Colin
I'll tell ya the 'tin can' has not leaked one drop, no spider webs, cleanest shed ive ever had, cold..yes, hot in the summer no.
gonna sort my build base soon enough.
Thanks for your nice comment Colin MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Good Morning Everyone MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Can I just chip in that a pine build board is probably the worst material to use, pine is prone to warp amd movement.
A minimum 12mm melamine/conti or MDF board avoids this risk.
Also its not wise to store a wooden model of any description in an outdoore shed, the changes in interior atmospherices from day to day be it sun one day and rain the next, can do all sorts of nasty things to the wooden framework of as model.
Thanks MR T, This board was the one I used for the Victory,its well cured, and I keep all my Models in the House, but as usual your advice is correct I appreciate your input. MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Sorry to here of your shed problems Budgie MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
When's issue 3 out is it Wednesday. Il be hopefully doing mine Thursday then putting up the pictures if I can ever work out how ta do it on my iPhone CURRENT BUILDS
Hi Sean, yes issue 3 is out on Wenesday, I am sure you will work it outwith your iphone MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
ISSUE 3 Picked up the above this morning, contains 2 ribs for the stern and a piece of false keel. MWG attached the following image(s): MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Guest (16)
