38 Pages «<3233343536>»
Garth's Black Pearl Options
#661 Posted : 09 September 2020 17:43:03
Very nice work Garth, what a show piece this will be.Love Love
Sticky Wickett
#662 Posted : 18 September 2020 07:02:09
Really looking the part now Garth. Excellent work!BigGrin
Phil W.
Garth
#663 Posted : 22 September 2020 11:54:39
tigerace wrote:
Outstanding Garth Drool the level of detail is amazing Drool Drool Love
Regards PhilCool
Hi Phil,
Thank you for looking in and for the kind words. Much appreciated.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Garth
#664 Posted : 22 September 2020 11:55:43
Hi Mark,
Thanks aswel for looking in and for the kind words. Much appreciated.
Kind regards,
Garth
Garth
#665 Posted : 22 September 2020 11:57:00
Phil W.
Hi Phil,
Thanks for looking in and for the kind words. Much appreciated.
Kind regards,
Garth
Garth
#666 Posted : 23 September 2020 05:59:02
Hi All,
I am going to interrupt the rigging at this stage and fit the stern lanterns. I have left them off until now as they are fairly delicate, and I really don’t want to damage them.
The lanterns supplied with the kit are obviously a generic stock item and do not look anything like the lanterns in the movies. Bored Some time spent with our beloved Rhino software and I had a lantern that closely resembles the ones on the Pearl.
Thanks, again, to Mark, the owner of our company, for the opportunity to 3D print a set of lanterns. The bottom, cage section and top were resin printed and the ‘glass’ was filament printed using clear material.
To light them I used a 5mm LED. I had some Ø2mm brass tube and as luck would have it, I couldn’t get both wires through. So, I soldered one leg of the LED to the brass tube – sorted!!!
When I wired the cabin, I laid the wires for the lanterns.
I glued the lanterns in and connected up the wires. I could only get white LED’s, so I gave them a couple of coats of GW Yellow ink. A pity they don’t match the rest of the lanterns.
While everything was still loose, I painted the lantern using my standard recipe. Matt black followed by light grey dry brushing.
Kind regards,
Garth
Garth attached the following image(s):
#667 Posted : 23 September 2020 13:57:57
those lights look fantastic
#668 Posted : 24 September 2020 08:23:08
Well done, those lights look fantastic.Love Love Love
goddo
#669 Posted : 24 September 2020 08:26:41
Hi Garth,
fantastic stuff with the lights.
Chris
#670 Posted : 24 September 2020 21:48:38
Garth
You are so skilled.
Those lanterns look brilliant how you have designed them.
You might want to think about a return on your investment and put them up on shapeways. Not sure fully how it works but i think the designer gets a cut of any sales of products they host on there.
Tony
#671 Posted : 26 September 2020 12:22:20
Excellent work GarthDrool Drool love it mate Love Love
Regards PhilCool
Sticky Wickett
#672 Posted : 01 October 2020 20:47:29
Those lanterns just 'pop' when lit Garth! Very nice. This is one helluva nice model!Love
Phil W.
Garth
#673 Posted : 03 October 2020 15:04:12
Hi Guys,
Once again thank you for all the uplifting replies. It's this kind of inspiration that keeps the process moving.
Thank you Tony for your suggestion regarding the 3D models. Things have been crazy at the office for the past month, but I will definitely look into it.
Kind regards,
Garth
goddo
#674 Posted : 04 October 2020 16:14:29
Garth, congratulations on the October award from MS.
Very well deserved mention I must say.
Chris
Garth
#675 Posted : 06 October 2020 08:14:51
Chris
Thank you Chris, really unexpected, but sincerely appreciated.
Kind regards,
Garth
Garth
#676 Posted : 06 October 2020 13:41:34
Part 09 The Yards
Making up the yards is prety much as per the instructions. Once again the mini lathe was invaluble when turning down the ends.
I painted them using the same recipe as for the rest of the model. Matt black folowed by a dry brush of greys.
One suggestion though, I packed each set in separate plastic bag and marked them Foremast, Mainmast & Mizzen.
If you are going to use my sails, then add the blocks as per my drawings.
Remember, only download the _Large drawings if you are going to use them as a reference to build from – no point in wasting data.
Kind regards,
Garth
07 Fore Mast Yards_Large.jpg (1,910kb) downloaded 47 time(s).
08 Main Mast Yards_Large.jpg (1,850kb) downloaded 50 time(s).
09 Main Mizzen Yards_Large.jpg (1,203kb) downloaded 50 time(s).
goddo
#677 Posted : 06 October 2020 16:05:20
Garth,
the most important part of your last post is the pic with the tea cup in it!!
#678 Posted : 06 October 2020 18:49:59
Impressive lathe work Garth.
Always good to see someone that can use one of these to get both ends of the spar nice and even.
My attempts in the past have never been ideal.
Tony
#679 Posted : 06 October 2020 22:30:04
That`s impressive work on the yards.BigGrin
Great use of a mini lathe. Cool Cool Cool
Looking forward to the next update.
#680 Posted : 09 October 2020 10:01:49
Outstanding skills GarthDrool Drool amazing detailBigGrin and congrats on the build of the month diaryCool
Regards PhilCool
