2 Pages 12>
Franzis 1/3 Porsche Carrera type 547 engine Options
kpnuts
#1 Posted : 24 October 2020 18:32:48
Hi all got this for my birthday, I'm well impressed, the instruction manual is a thing of beauty I've never seen one like it before.
It is full of history and information also loads of beautiful pictures of the cars this engine was in.
The actual instructions make up about a third of the manual and are also beautifully printed and clear to follow.
The box is huge, good quality and stuffed to the brimm with high quality plastic.
I'm intending to build this as half see through rather than completely see through as is intended with the kit
#2 Posted : 24 October 2020 18:51:06
Wow Ken, Drool Drool
That`s darned impressive at 1:3 scale.Cool Cool
Bring on the diary, I`m in for this one.
kpnuts
#3 Posted : 24 October 2020 20:37:56
So I've started the crankshaft and pistons
I've built the casings of the half I'm going to paint, we have a machine at work called a vapour blaster which we use to clean engine parts which I'm hoping to use to give these parts a cast look (it uses tiny glass beads and is only supposed to remove 30 microns on metal parts will try it on a piece of sprue first)
CaptnBirdseye
#4 Posted : 24 October 2020 21:20:03
Rank: Superelite
Drool WOW! All I can say is ‘WANT ME ONE OF THEM Love Love Love
kpnuts
#5 Posted : 24 October 2020 21:57:28
Its a great kit company started in 2016 so all new tooling (its a German company) they make loads of famous engines im interested in the mustang v8 and the Porsche 2 liter flat 6 (already asked for the 1/2 BMW r90s engine for Xmas
kpnuts
#6 Posted : 25 October 2020 18:55:20
Hi all more work on the engine, im certainly getting a lot of practice creating metal effects on this one.
RM1
#7 Posted : 25 October 2020 19:29:00
Great looking kit you've got there Ken and your doing a great job.
Malc.
#8 Posted : 26 October 2020 09:17:37
What a fab kit. Nice work Ken.Love Love
kpnuts
#9 Posted : 26 October 2020 21:33:54
Hi all one of the advantages of having a 547 engine completely dismantled at work is loads of reference material, for instance this main drive gear should have 6 30 mm holes in it, 1/3 equates to 10 mm
I also took the half I'm painting aluminium to work to vapour blast it (for a cast effect)
And the first coat of the casting effect
#10 Posted : 26 October 2020 21:37:04
Looks like a great kit you have there Ken.
Lovely work so far.
Now - if they did a 1/4 scale Cosworth Ford V8 I'd have one for my big Tag Williams...BigGrin
kpnuts
#11 Posted : 26 October 2020 22:03:04
They do a 1/4 mustang v8
kpnuts
#12 Posted : 27 October 2020 21:55:48
More work on this, been adding a few bit of discolouration to the ally side, got a bit more work to do on those effects yet.
Still loads more bits in the box.
#13 Posted : 27 October 2020 23:05:27
Hi Ken,
Looking good and a great bit of spraying to.
Trev
kpnuts
#14 Posted : 28 October 2020 22:01:25
Well I've got the valves installed worked some more on the casings getting happier with the results (I think maybe its too shiny needs dulling down a bit) I don't want to make it look grubby just weather worn and aged.
#15 Posted : 28 October 2020 22:31:51
Looking good Ken, BigGrin
I like the way you are doing the half and half version so you can see the workings on one side and the castings on the other. Well Done.
Cool Cool Cool
kpnuts
#16 Posted : 30 October 2020 22:39:44
Hi all more work on the valve gear
https://youtu.be/wG8IpL55tx4
kpnuts
#17 Posted : 31 October 2020 21:00:15
Hi all started on the exhaust down pipes (dosent really show in the pics)
I tried an experiment with metal effects on the exhaust as I didn't want it to look the same as the engine and im really pleased with the look of them.
#18 Posted : 01 November 2020 10:15:17
Nice work on those exhaust pipes Ken. Love
kpnuts
#19 Posted : 01 November 2020 18:53:33
Got the exhaust on and more experimental metal effects, a word of warning to anyone building this kit and painting parts of it the black shiny plastic is of a different type of plastic to the rest of the kit I sprayed the cowl for the fan (with the same type of paint used everywhere else) the plastic on the cowl has crazed and cracked (and that's even with using plastic safe primer) im hoping a layer of filler sanded down then sprayed over will fix it.
kpnuts
#20 Posted : 03 November 2020 21:34:46
Nearing completion now.
2 Pages 12>
This page was generated in 0.159 seconds.
