Really nice work Roeland.
Making a beautiful job of the rigging, Roeland. Chris
Joined: 23/09/2018 Posts: 154 Points: 471 Location: Cape Town
I added reef tackle... Roeland attached the following image(s):
Bowlines and reef tackle for fore mast complete.... Roeland attached the following image(s):
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,282 Points: 22,153 Location: Northamptonshire, England
Very nice work.  I always admire anyone that can do these period ships. Mark Regards Markwarren (Mark) Admin
Today I fitted horses to the jibboom and flying jib and also managed to squeeze in bowsprit netting. Roeland attached the following image(s):
Looking very impressive Roeland, very well done.... Regards Alan
Main to sail ready to take bow lines. Roeland attached the following image(s):
Looks stunning. Credit to your patience with all that rigging. Well done. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Bowlines are now fitted to the main top sail. I also added 2 bowline blocks under the cap of the foremast for the bowlines. The latter was a nightmare to install and I had to undertake some remedial work to other parts of the rigging. Roeland attached the following image(s):
I added brail lines to the mizzen staysail - I'm not sure if this would be historical correct? Roeland attached the following image(s):
and some home made 3mm blocks to the sheets.... Roeland attached the following image(s):
I started adding some deck coils. Roeland attached the following image(s):
and tied the mizzen shrouds Roeland attached the following image(s):
So impressive Roeland, your eye for detail is incredible.... Very well done.... Regards Alan
I added some super small coils on top of the flag lockers and rigged the sheet lines of the main stay sail. I used an alternative method for this with hand made 3 mm blocks and eye bolts. As the wind in the sail blows from the port side I tried to slack the tension on the starboard side sheet line. Roeland attached the following image(s):
That looks so nice. You have done a brilliant job on all of that ropework. Tony Happy Modelling
The main topmast staysail is now rigged. I added brail lines, a downhaul and used an alternative method to connect the sheets - some of it6 I made up (a bit). Roeland attached the following image(s):
Except for 2 downhaul lines all the staysails are now in position - I'm happy with the overall progress so far - perhaps a couple of hundred hours to go. Roeland attached the following image(s):
